ZolaIII
- Joined
- Jul 28, 2019
- Messages
- 5,312
- Likes
- 3,167
In my (limited) experience on Panasonic TV's you can change analog unbalanced outputs either to be line out or variable, also you can adjust optical (Toslink) lv in a ±10 dB range but that isn't handy and besides it's meant for proper input limiting (of power amplifiers) for line continues output.Perhaps, but for many controlling the volume with huge up/down volume controls on the 85h headphone cups is pretty convenient.
If you wanted to control via the TV remote then a cable from the TVs RCA out would work as long as its output is variable. My background is audio sales rather than the tech itself, so I am pre-disposed to ask too many questions on use case before offering advice. For most people it is confusing to have competing volume controls both on the source and on the headphones.
I am complicated person (to extent I even downgraded my main desktop in order for it to have Toslink input)! Still there is absolutely no way nor will even best leveling solution iron out output volume differences between different broadcasters. So it's good to have responsive volume control's under a trigger. EU attempts with EBU R128 are for prizing even in EU it doesn't apply everywhere obligatory. I use it internally and it's good for both music and video up to THX cinema DR. Why things are like that in broadcasting jungle is beyond reasonable discussion.
From cheap dongles for rather sensitive IEM's and headphones (500 mV max) the Apple EU USB C dongle is very good but it won't work with Android (it will with output volume adjustment in UAPP on system lv without need of owning it). For main stream mid sensitive ones the 2V CS43131 based one's are still best solution for portable or BT one's. If you want/need more additional OP amps stages, balanced and so on come into play but it really isn't supposed to get into portables (regarding efficiency). A clip alike BT one's with support for BLE related codec's, LDAC and other property one's start from around 50$ in a form of alikes Hiby W3 II. If you want rather good quality and low latency over BT use LHDC and good luck with it even on very new Android phone (BT 5.4 part for full compliance and still only if implemented good and you pick/check it in developer options). In my case as I stream only latency not sensitive content (music) it work's anyway.
