Headphone Correction & Spatialization
dasdoing
Salvador-Bahia-Brasil
I like your filter better than Waves, but none of these make me think I'm listening to speakers. I think I prefer CanOpener.
I will let you chose a song for my 2.0 version. actualy I kind of treated the first version like a beta, since I wasn't realy fully happy with it
whazzup
If you're looking at speaker virtualization, I've personally had the best results from Out Of Your Head (OOYH) software, though it's more of an end-user software, not DAW plugin.
https://fongaudio.com/out-of-your-head-software/
There's a discussion on OOYH (where the developer drops by as well) at Head-fi:
https://www.head-fi.org/threads/out-of-your-head-new-virtual-surround-simulator.689299/
The software is finicky, but when it works, the presets (recorded with the Realiser A8 hardware) do allow that feeling of listening to speakers from headphones. It's not going to cut it when you start to listen critically, but for me, of the similar technologies out there, it's the most successful so far in removing the sound pressure you 'feel' on your ears when listening to audio through headphones, and create the impression of sound coming from the front. Within OOYH, I feel the Sonus Faber Elipsa and Genelec presets get the closest to mimicking speakers.
Haven't had the fortune to hear the Realiser A16 though. And also haven't tried NX other than listening to their web demos.
whazzup
I tryed all kinds of crossfeed/vitual room aplications and they all sound shit. Best I found is Abbey Road Studio 3, but it still colorizes af.
So I took some binaural IRs from WDR studios and tweeked it until I got most colorization out.
at the time I had a wide angle setup in my main speakers so I used a wide angle for this. I will create a regular stereo triangle version in the future since I went back to the standard:
The voice still sounds like it's inside my head, just more diffused / crossfed (?) when compared to the original track. And the telltale signs of feeling the 'sound pressure' on my ears from the headphones. It's definitely not easy, good luck!
dasdoing
personaly I only hear the hard panned sounds "in my head"
the other song I posted with my filter is not hard panned and I don't hear it "in my head".
creating a filter like this is not easy, because if you leave a lot of "virtual room" it sucks, if you remove it stays "in the head".
my personal goal was to create not a filter that represents real speakers in a real room (it sucks on headphones), but to create a filter that represents utopic perfect speakers in a utopic perfect room. I apreciate the critics. I will try to leave more room in the next version.
this is if I don't like OOYH, which I will test, since if I like it I have no reason to make my filter better
whazzup
Sure. The installation process can be a headache, as the developer creates a driver that sorts of rides on top of your current audio device. If you switch between audio devices like multiple usb dacs / onboard sound, you can encounter issues like no sound coming out. Reinstalling and restarting worked for me. But my computer is close to 10 years, the usb ports may not be very robust / well supported in Windows 10, so you may get a smoother experience.
Guermantes
Brisbane, Australia
I was listening to a classical album this morning during my daily commute:
https://www.deccaclassics.com/au/cat/4758237
I was listening on IEMs and my DAP has no cross-feed or similar function but I was struck by how the soundstage of the Henry Cowell piece was less "in-my-head" and more panned across the front though rather close -- much like what I would expect of a chamber orchestra -- but not necessarily equivalent to speakers-in-a-room. This is a recording that seems to translate well to headphone listening. I am listening to it now on a pair of Genelec 8260As and it still has a nice natural image. The engineer was Stan Goodall and he probably used a Decca Tree -- three omni microphones in a T configuration.
So this made me think: As a content creator, should I be considering headphone listening as a target? In other words, should mixing for speaker listening still be the primary reference when consumers are possibly spending more and more time with headphones? And how do I get my recordings to sound satisfying on both speakers and headphones? I consider both to be necessary compromises with attendant idiosyncrasies, some of which we have become quite psychologically attached to.
@andreasmaaan Perhaps you can try your mixes with and without speaker-simulation and see if they are commensurable between the two listening paradigms. I'm thinking about replicating a Decca Tree effect on the master bus and see how that affects imaging, though the success or failure of this might depend on how much it violates generic expectations.
Just some thoughts.
Bob-23
Berlin, Germany
That's the point, we need recordings that are, at least, mixed for headphones, and/or, even better, particularly recorded for headphone listening. All the measures we take in order to correct for recordings that are mixed on boxes for listening on boxes will rest somehow imperfect, however good the are. That said, headphone listening, corrected by crossfeed, nevertheless, has some advantages over listening on speakers: you are always in the sweet spot, you get all the details, and no room reflections fake the sound. So, listening on boxes is, mostly, imperfect, too.
Bob-23
Berlin, Germany
Just some thoughts.
I forgot: "Longtemps, je me suis casqué de bonne heure."
Guermantes
Brisbane, Australia
:D
dasdoing
my sub broke, so I figured I do this project today (testing OOYH and creating new version of my filter)
first song is Spanish Harlem by Rebecca Pidgeon.
I choose this song since OOYH has a processed version (for demoing) on their website
processed with my new filter https://drive.google.com/file/d/1VeTZ0Y0sU4o-OU9YA8l8DmhiuRV5hgYO/view?usp=sharing
processed with ooyh (volume brought down to match +or-) https://drive.google.com/file/d/1vbyTvOlPVfnHJHpalv472ts5BivEDm7J/view?usp=sharing
since many hear don't like treated rooms (and prefer bass boosted house curves) I processed another one with a filter (Room1) of this dataset (Ash-Ir) of a less treated room https://github.com/ShanonPearce/ASH-IR-Dataset
https://drive.google.com/file/d/14LCNbPJcf3GmFNJSOOqThsNVbhlE71aM/view?usp=sharing
second example is Dvorak 9 (Viena Phil)
processed with my new filter https://drive.google.com/file/d/10QY8lxadRyIybXqEZFG6ikphBzlSxmPC/view?usp=sharing
Ash-Ir_Room1 https://drive.google.com/file/d/1pbCsxwB1Zo1T2IUwYJCV8gYkUy1ONdHQ/view?usp=sharing
EDIT: so what do I think of OOYH? it is very colourized (mid heavie), like all the other solutions I tested. visualy comparing Spanish Harlem files in Audacity, my filter produces waveforms very similar to original, OOYH on the other hand is very diferent
phoenixdogfan
Nashville
I actually own the A16, and had it shipped to me. It locked up and had to be sent back for service, and I'm awaiting it's return. I've not had a chance to test it out. I also own and have used OOYH for five years, and I find it to be the most impressive of the software based solutions. I also owned the ToneBoosters plug in and never thought it was very good. OOYH, however, did get the image to a point where it seemed to surround my head, but at a very close distance--kind of like near field surround sound. Darren Fong is also great to work with--very nice guy and very service oriented.
OOYH only works for some people, and only with certain presets. The software has 23-25 presets and only two worked for me. Some were absolutely horrendous--like the one taken in a theater--while others seem like the speakers are playing 50 feet away in an underground cave. So never was the phrase YMMV more true--but he does offer free try out, so you can find out if it will work for your individual head, as well as which presets will work for you.
3125b
Germany
Sounds pretty horrible.
Honestly, they are all worse than just the original file.
If I want to listen to music with speakers, then I use my speakers, if I want to listen with headphones, I use my headphones. But to each his own I guess.
whazzup
I'm not a hardware/software engineer, but I'll try my best to give my subjective comments. I alternated between the 2 versions you uploaded, as well as the various presets on the OOYH app itself (while playing Spanish Harlem from Spotify), and of course playing it from my speakers.
If it matters, I'm using the Sennheiser HD598 headphone.
Your filtered version: The reverb is too strong? Sounds too much like a cave, and it makes her voice sound more hollow.
The OOYH version: I tried testing the various presets, but I don't know which preset was used exactly, sounds like the Revel Ultima or Marten Momento V2 preset was used. However, I can say that while there's still reverb (both in the pre-recordable file and (some of) the better presets), her voice is still clear, and 'closer' to what I can hear from the speakers in front of me.
I do not think producing waveforms closer to the original means anything....you can think of it this way:
Source file (Waveform A) > Speakers Output 'recorded' by our ears (Waveform B) <---- desired
With headphones, now the 'speakers' are strapped to our ears, it becomes...
Source file (Waveform A) > Headphone Output 'recorded' by our ears (Waveform C) <---- undesired (*from virtual surround perspective)
Then the virtual surround filters come in and they seek to make...
Source file (Waveform A) > Find how Waveforms B and C are related, plus consider the equipment (speakers / room / headphones) then somehow magically make a filter that produces > Headphone Output (Waveform D), that sounds like Waveform B
I am obviously grossly understating the process here, but my feeling is while Waveform D will still look like a variation of Waveform A, it probably needs to be transformed in weird ways just so that it gets 'interpreted' by our ears as Waveform B when it comes out from headphones.
You may want to talk to the developer for the Impulcifer software as well
https://www.head-fi.org/threads/recording-impulse-responses-for-speaker-virtualization.890719/
whazzup
Same, some of the presets don't really work for me too, I think the room where recording was done makes a large difference. Hope when you get the working A16, give us a review.
whazzup
True, a lot of people still feel DSP and equalizers are evil....:D
dasdoing
If you like the headphone sound you have nothing to fix, and obviously any alteration/compensation, even the perfect one if it exists, will sound worse to you.
You are right. it sounds crap. made the mistake to produce the result on the same day, without hearing it on fresh ears. When I first created a filter last year I could only solve this be producing a minimum phase version of it in REW. But this destroys the spacial ilusion. Also cutting out reverb with a window on Rew destroys the ilusion. atm I am stuck.
It's not that I tried to maintain waveform, I just looked for a reason why the OOYH proccesed file sounds so thin.
I wasn't aware of the various presets of OOYH. I sould try the demo version. The spatial ilusion is great, I just didn't like the strong colorarion of the demo song
whazzup
Haha, with regards to creating filters, I'm useless to you.
Yes, personally I don't think the pre-recorded demo song is a good representation, BUT it could also be a matter of headphones. There're so many variables unfortunately.
odyo
I also find that auto eq and oratory eq really bad for my taste. Sonicworks as well.
