solderdude
LInky to the seller perhaps ?
Pretty cool idea honestly.Question on headphone cables regarding the brand Ursine. They have a new “system” called premium-sleeved-single-strand-system, here is the link https://squareup.com/store/ursine-a...d-single-strand-system?square_lead=item_embed the cable is two parts(amp termination up to y and then y to headphones) and connects with I believe a mini-4pin xlr, what are your thoughts on This cable? It seems like it would make it where you buy one system for whichever headphone then for the rest of your headphones you just buy the y split to headphones and connect to the cable. Would there be a downside to this system?
I mailed with the Ursine guy before and he told me his premium clothed sleeve is ultra-soft/flexible and should be minimally microphonic. I actually have the non-modular version on the way but I haven't had an update on the tracking in weeks (Intl shipping). might be lost in mail reallyCool idea a modular cable.
The price for the total cable + shipping (adds $ 40.-) is kind of on the high side for my preference but certainly not 'high-end' priced.
The cable itself is cloth covered which means it is probably more microphonic when rubbing against clothes and the cable looks a bit thick/heavy/stiff.
Most people looking for a cable replacement often look for these properties thinking it must sound better.
It arrived today! Cable is his "premium sleeved" one, in my case for AKG termination. I opted for eidolic connectors. Cable is very very soft and sleek, oozes premium quality.Lets hope it turns up. Have had some packages lost in the mail as well as some that took months but arrived.
Sometimes they turn up a few days after I filed a complaint.
Let us know how the cable is (quality wise) I still think its a lot of money for some copper wires and 4 or 5 plugs.
I'm having trouble finding a balanced headphone extension cable (4-pin XLR M/F) that's not too long. I want 6' to 10'. So I'm going to buy some cable and connectors and build it myself. (Unless you have a good suggestion.)
A few questions for the experts:
- Will Star Quad make any difference v. regular Canare or Mogami ?
- I can buy this one at $0.59/ft https://www.markertek.com/product/l...-star-quad-microphone-cable-by-the-foot-black or Audioblast HQ-4 for a whole $0.41/ft more. So cost isn't a factor but is there any possible quality difference?
- I'll probably buy these connectors (M & F): https://www.markertek.com/product/n...emale-xlr-cable-end-black-shell-gold-contacts Any tips on soldering or other assembly issues to be aware of?
My headphones are 110 ohm, flat WRT FR. So, if I understand correctly, 10 feet of Star Quad will add 0.3 ohms and has a completely flat FR itself.Depending on the headphone impedance I suggest to look for cable resistance (thickness of the wires)
The Neutriks are more than fine, there is plenty of room to solder in those plugs.
The Canare works fine as well.
Stiff and sleeved and braided headphone cables have a tendency to do that.
The above, appropriate length and weight are reasons for me to look for a thin and supple as well as smooth replacement.
