Headphone amp low-volume listening
JackStraw5877
Oregon
Hi Folks,
Apologies in advance if this has been covered somewhere else, as I was unable to locate a relevant thread...
I enjoy low-volume listening and was wondering what the most relevant measurements in headphone amps I should be paying attention to?
SINAD at low output? Channel balance?
Also, any specific model recommendations for HP amps in this context would be appreciated.
Thanks in advance!
THD + N (especially noise!) at low impedances. You also should pay attention to the channel balance when analog volume controls (pots) are used. A low-gain or input attenuation selection can help to alleviate the distortions with sensitive headphones. It will also make finer volume adjustments much easier.
What is your budget?
Thank you Dreyfus,
I feel fortunate that at this time my budget allows for the Benchmark HPA4 (I also need preamp for actives/power amp for passives). This is my absolute max budget ($3,100 USD).
However I am also interested in RME ADI-2 and Topping A50/D50 combo.
My cans are Focal Clear Pro and ZMF Auteur in the future (hi and low impedance).
Hope this helps, and thanks again for the reply.
Your recommendation doesn’t have anything to do with the country whence it was sent, does it?
Joking aside, I seem to continue coming back to the RME, and this would certainly save me some money.
Thanks again kind Sir.
The RME has a headphone out.
I should think it would be sufficient for your low volume listening.
My Benchmark's phone out is.
Using a Focusrite 4 Pre USB's headphone out now - just because.
I don't have a standalone "headphone amp", just devices with headphone outputs.
Disclaimer: I've not been driven insane with headphone fantasies, and use HD650 , "the safe choice".
Good feedback Ray, thanks.
The Benchmark’s channel matching looks so solid, especially for analog.
I just can’t help but think about how the price differential between the HPA4 and RME could allow me to buy more cans/better speakers.
It’s interesting that you’re recommending the RME as an HPA4 user...
I like RME for their exemplary driver support, build quality and technical robustness. The ADI-2 is a very well designed piece of hardware which will serve you for a long time. I just bought a used PCI-based Multiface which was released around 2008. Still works flawlessly with Windows 10. There is a good reason for the low price decline of their products.
Shhh, no worries! :D
