A success!I replaced the USB cable to a superior USB cable, and now the sound is about the same
After prolong listening I have to say that sound wise the HDMI is still better.A success!
I need to extract USB audio from an HDMI stream
It can be done but requires a computer in the loop. Your best bet with the D50 is HDMI->SPDIF->D50 (optical or coax). If you mean true HDMI signal. I2S can be sent over HDMI cable but it is not the same as HDMI you get from say a DVD player.
https://www.monoprice.com/product?p...8lWgTtAmWEoKsuAZaQ7rl5OEnmHy-PhBoCPgMQAvD_BwE
I wanted to extract the audio off of the HDMI stream since I expect it is going to be much higher fidelity than SPDIF.
No, it is not better. Just use the Toslink output from the TV into D50, that's the best you can do.
All recent TVs downsample to 48kHz/16bit via optical out, so there is a theoretical benefit to using an HDMI de-embedder, but the difference probably isn’t audible.
I found that on eBay, and I can't confirm that this will do the trick but it mightHello, I stumbled on this thread because I need to extract USB audio from an HDMI stream. Unfortunately I do not have the benefit of having an I2S DAC and am using the Topping D50 so need USB. I did not see a solution which permitted HDMI-->USB Audio extraction in this thread. Does anyone know of any solutions here?
It has no usb, so how does it help?It can be done but requires a computer in the loop. Your best bet with the D50 is HDMI->SPDIF->D50 (optical or coax). If you mean true HDMI signal. I2S can be sent over HDMI cable but it is not the same as HDMI you get from say a DVD player.
To me it doesn't sounds very simple, and I believe that that Everything should be made as simple as possible. (but not simpler)It was an example of how you can convert HDMI to SPDIF. To convert to USB output you can then add a USB audio interface with a Toslink input or something like USBstreamer to read it on computer and send to a USB audio device with the help of some audio software, JRiver can do it.
Also Merging.The other two I'm aware of are the exaSound and Motu.
Thank you. I realized, for my special HT situation, HDMI to okto is not needed. For highres Video/Audio I want to use a Mac/pc playing from jriver or roon over usb.I received a private message asking about how to get multi-channel HDMI audio to an Okto Researc dac8 PRO. It's a good question. The Okto dac8 PRO is one of only a few commercially available 8 channel DAC's. The other two I'm aware of are the exaSound and Motu. All of these DAC's are intended to be used with USB input, which is fine if your source is computer, but not very useful if your source is a Blu-Ray player or streamer.
I don't have a simple answer, apart from some complicated DIY solutions, but long term it may be worth lobbying these companies to add a direct I2S input to their DAC's. Then an intermediate HDMI extractor device can be used, such as this -
https://www.audiophonics.fr/en/diy-...-hdmi-mhl-to-i2s-coaxial-optical-p-13419.html
Maybe someone else can jump in with a solution.
Unfortunately, the Vanity is pretty much discontinued (except for the old BDP-93).Edit: For blu-ray players Okto „recommends“ oppo players with vanity extension card on their website. The vanity extension offers 4 RCA outs, which can go also to the 4 AES EBU ins of the okto. Unfortunately used Oppo players became really expensive.
