HDMI ARC/eARC: How To Convert/Extract Audio?
tccalvin
Is there any high-quality converter that can make HDMI ARC/eARC devices (like a TV/Monitor) work with DACs that are not equipped with HDMI inputs?
I'm mainly interested in preserving a lossless digital signal rather than the ARC/eARC control functionality.
Yes the Vanity Pro comes to mind, it was reviewed by Amir.
ARC, very easy: a random HDMI extractor with ARC capabilities and spdif output, there are many
eARC, very difficult and/or expensive. The good news is that if you dont need multichannel, ARC is probably enough
How about this?
Your old TV/monitor connect to HDMI OUT.
Apple TV or other TV box connect to HDMI IN.
Fosi ZD3 or other DAC connect to eARC/ARC.
In addition to EZCoo / CorsaHD (same thing), there are several options that might be able to do what you want:
  • Blustream SM11EARC-8K
  • FeinTech AX310
  • FeinTech AX211
  • J-Tech 8KAE
  • Marmitek Connect AE34
  • Navceker HDMI 2.1 Audio Extractor
  • Orei BK-931
  • Orei BK-929
  • Orei BK-927
It would be worth looking up HDFury and FourKay as well.
The last sentence is a seperate suggestion yes? Because if you had a ZD3 you wouldn’t need the Ezcoo…
You must have Fosi ZD3 to receive audio signal in HDMI eARC. The old TV doesn't have HDMI eARC. And, the Apple TV is the main source for Apple Music Hi-Res Lossless which come only from HDMI, cannot SPDIF optical from TV.
So, Bob is your uncle, Hi Ress Lossless 24bit-192Khz Apple Music to your speakers.
I must be missing something. Is this thread about multi-channel music? because I don’t see it mentioned in the OP… or is that to be implied as he asked about HDMI?
Fosi ZD3 or other DAC connect to eARC/ARC.-
Can’t the last step be SPDIF to the DAC? for “Hi Ress Lossless 24bit-192Khz Apple Music to your speakers”
I have found some suitable candidates for my use-case:
and
Of course, who knows how they perform in terms of jitter... The only way to know is to try them out. :)
Apple TV does not have screen. It's a TV box/streamer only. Where to show the display? Does Fosi ZD3 or other DACs have screen? Where is the screen? Inside the box?
i use this adapter https://www.sonos.com/en/shop/optical-audio-adapter
to utilize the WiiM Ultra HDMI eARC input , to connect CD player as transport (with optical out)
it's cheap and it works
Plug an HDMI cable into your TV, or a dumb display of your choice.
No of course not, these are just for the AUDIO part.
The topic here is devices that extract the audio signal portion, separate it out from the video.
Do some googling there are a lot of basic level explanations out there
"Because if you had a ZD3 you wouldn’t need the Ezcoo…"
So, how to show the display of Apple TV? I don't think Fosi ZD3 or other DAC have projection screen inside the box.
read the first line of the response you quoted.
You must have a separate display, in order to view the video content.
Most people already own a "TV" into which they may plug all manner of video streaming devices, maybe Roku, set-top boxen from a cable company, tuners for OTA reception, computers with movie files on them, etc etc
