unless you do it like in the video. it is a moot ventureHello all,
Is there any EQ Profile so as to import to Peace, for my HD600 that can "sound" like HD 800S, so as to have fun and test it as it is described here at 07:22?
Thanks
Thank you! This is what Headphone guys did in the video cause I do not get it?Download the frequency response .CSVs of the HD600 and HD800s from here: https://github.com/jaakkopasanen/AutoEq/tree/master/measurements/oratory1990/data/over-ear
Open https://autoeq.app/, load the HD600 file as headphone and the HD800s file as target.
Select Equalizer APO Parametric Eq as Equalizer App and the website will generate a correction preset which you can download as .txt and import into Peace.
I do not clearly understand the way they did it, that's why I ask if there is any ready profile so as to import and find out if I like it.unless you do it like in the video. it is a moot venture
anyway test this preset I have capped to under 3500Hz:
my preset like I clearly labelled is up to 3500Hz. beyond that I can't confidently get the matching rightI do not clearly understand the way they did it, that's why I ask if there is any ready profile so as to import and find out if I like it.
The attached preset is what they did? Or is your own testing profile?
Thanks a lot
What is it that you do not get?Thank you! This is what Headphone guys did in the video cause I do not get it?
The measurements are done with the headphones on the person's head, with in-ear microphones. These measurements capture* the unique headphones-to-eardrums sound transfer characteristics of the person as each person's pinnae are unique and different.I do not clearly understand the way they did it, that's why I ask if there is any ready profile so as to import and find out if I like it.
Thanks a lot
I thought that we all could get the profile they have for HD600->HD800s, so as to test it, even if it is not measured for our heads of course, and I f the solution you provide cound be similar to a profile the Headphone guys useWhat is it that you do not get?
Does not work that way.I thought that we all could get the profile they have for HD600->HD800s, so as to test it, even if it is not measured for our heads of course, and I f the solution you provide could be similar to a profile the Headphone guys use
