HD660S balanced cable problem
Nimbus2000
I have hd660s and have been using it with the unbalanced cable with the fiio q1 mk2 . decided to try balanced so I bought theses two adapters
https://www.amazon.com/NewFantasia-Balanced-Female-Headphone-Adapter/dp/B07YWJ47XC
https://www.amazon.com/Female-Balanced-Silver-Plated-Adapter/dp/B07XPBGJ8X
To use the balanced 4.4 mm cable that comes with my headphones but the right driver doesn't work , I suspect because off the stock cable because when switched the cable because when I plugged the left side in the right driver it worked , but I feel that the stock cable isn't fitting very well in the adapter . How can I fix the cable without buying a new one any help is greatly appreciated .
