HD 560s VS Ft1 Pro
matigimenezlopez
I'm going to adquire my first pair of hi-fi open headphones, and I'm considering the hd 560s and the fiio FT1 Pro.
Unfortunately I can't compare them or test either. I can only say that I've been using a pair of HD 280 pros for 3 years as they're the only pair of headphones that I own
I plan to use them for guitar amp modelling with rock genres, as well as folk genres when I'm not playing. All of this through an Audient ID4 MKII
Sparky treble isn't exactly what I'm looking for as these rock guitar tones will likely be more fatiguing
Could anyone who has tried both guide me on which ones are more suited?
I own the Fiio FT1 Pros and have used my uncle's HD560s with EQ.
The FT1 Pros have a QC issue that causes extremely audible distortion in the bass akin to clipping with bass EQ.
Look at these distortion measurements: https://forum.headphones.com/t/fiio-ft-1-pro-measurements-official-discussion/24674
It goes from less than 2 percent in the subbass at 94db up to nearly 10 at 104db and 20 at 110db. HD 560s, at least, can handle 104db. And when I stress tested them the clicking Amir also heard in his review was much less annoying.
If you hate sparkley treble, the HD560s has some small measured spikes I didn't really notice, and as for the FT1 Pro, I preferred the -3db 10khz high shelf I saw on Oratory1990's preset.
From 24th to 27th September Sennheiser offers 20% discount on most products in their online store. And the Sennheiser Outlet has refurbished items at reduced prices.
I'm going to aquire my first pair of hi-fi open headphones, and I'm considering the hd 560s and the fiio FT1 Pro.
Consider the JT9 instead of the FT1 PRO.
HD 560S is also a good choice.
Thanks!
I just bought the HD 550 for 160€. Curious to try it out.
I have the Fiio JT7 and the HD 560s at home at the moment. Soundwise I prefer the JT7. With a bass shelf and some treble reductions, it is a really great headphone. Especially considering the price. But for me it is not very comfortable. The 560s is super comfortable but the sound is not to my liking. I am a bit sensitive to treble and it is harder to get the 560s to sound decent for me.
I have a pair of HD 550s, and they're decent-sounding headphones once you EQ them, especially in the bass region, where they sound way too anemic out of the box.
I got the FiiO FT1 Pros this Monday to try them out. Honestly, nothing particularly special. The bass issue isn't present on my pair, or at least I don't hear it at a level where it's noticeable. However, they have a resonance around 3 kHz that absolutely drills into my head, and that's going to be a deal-breaker. They'll be going straight back to Amazon.
Thanks!
How would you compare the JT7 to the HD560S? I'm looking to get the JT7 or the HifiMAN 400se, but I don't know which would be better in terms of sound, build, and other things. Can you do a deep dive? Looks like you've been round the block a bit. (:
