HD 560s gaming
folkswavy
Planning on buying the HD 560s for gaming. Just wondering what are some good amplifiers for it for budget and mid tier.
Hi @folkswavy! Welcome to ASR.
Here are some good options:
AmpMax playback volume with HD560Sperceived Loudness
80dB▄ (0.2x)
Apple A2049106dB▄▄▄▄▄ (1.0x reference)
JCAlly JM20 Max/FiiO KA11114dB▄▄▄▄▄▄▄▄▄ (1.8x)
Topping DX1118dB▄▄▄▄▄▄▄▄▄▄▄ (2.2x)
Personally, I listen at moderate levels of at most 80-90dB Peak (first column for reference), so I'd choose the Apple A2049.
As for sound quality, maximum volume is the only differentiator.
Detail, bass, soundstage is identical on 95% of DACs and Amps you can buy today.
If your PC makes a lot of noise whilst gaming then closed headphones might be a better option, 560s leak in a lot of sound
