Vini darko
After using these for a few days outside and around the house. I've ended up with this warm EQ curve. Definitely agree that upper treble is a touch much for long listening without EQ.
It's not the first time KZ changed things mid production, after sending out review samples that got well received. Well done, Blorg!I have the new, high treble variant. It's very bright, no way getting around this, it's extremely bright. I'm not that sensitive over 10kHz but it's very very bright in the high treble, I can't imagine a young person could possibly listen to this. Sharur has his issues but no one who can hear to 20kHz could hack this without EQ, the treble is insane.
I need -6dB high shelf from 8kHz for it to be listenable, and I'm older with poor high frequency hearing.
There are two versions of this, KZ did an initial collab with HBB with reduced treble, found that was too difficult to manufacture quickly and removed the treble damping so it's now back to crazy high treble. It's a total bait and switch.
Old one has this black rectangular damping directly on the driver, new one it is missing. KZ admit this was a change but they deny it affected the sound. But this is nonsense, NO ONE complained about the original having excessive high treble, some even thought it was on the dark side. But lots of people are finding the V2 too bright.
My (new) one vs the old one, it's a treble monster now. Totally different IEM. This is with foam, it's even worse with silicone tips, and it's highly dependent on insertion depth too with silicone.
Comparison from Paul Wasabii of different measurements, you can see the new ones with the high treble:
modernGraphTool
View and compare frequency response graphs for earphones/headphones.paulwasabii.github.io
What a stupid way to ruin the reputation you were just beginning to recover, ruin your working relationships with content creators, and waste a lot of money spent developing your driver tech(correct me if I'm wrong but they're the only ones using that planar driver as far as I know so I'm assuming it was developed in-house). I get the margins are tight but surely a better way would be to honor the existing preorders, and then just increase the price for the remainder of production if the original damping method was harder(ie more expensive) to do. Really feel bad for HBB here.I have the new, high treble variant. It's very bright, no way getting around this, it's extremely bright. I'm not that sensitive over 10kHz but it's very very bright in the high treble, I can't imagine a young person could possibly listen to this. Sharur has his issues but no one who can hear to 20kHz could hack this without EQ, the treble is insane.
modernGraphTool
HBB commented on it, I think he has accepted there are two versions now:
One other point of interest, and very surprising for a planar, is that the PR2 is sensitive to output impedance, and an impedance adapter drops the treble:
This actually fixes the brightness 100% but unfortunately it starts dropping it from 3kHz rather than 8kHz which is where it really needs it. It makes it just a little dark in the 3-8kHz region. The V1 kept the pinna gain in that region but muted the higher treble, I haven't heard it but the graph looks about perfect. With this it is a lot more natural sounding though and part of the "sounding dark" is probably from direct A/Bing with it stock which is insane treble levels.
KZ did mention tweaking the "PCB" in the V2 as well, to compensate for removing the physical treble damper. So there does seem to be an electronic component in the IEM that presumably is what is giving it a non-flat impedance curve, and probably also what makes it so hard to drive.
What a waste of copper, you could instead twist on some miniaturized resistors in an adapter plug, if this is the avenue you are considering.I thought about buying the chunky 784-core cable on the grounds that less cable resistance is better
I measured the stock cable vs a thicker Xinhs one, it's not a significant difference. Stock might be slightly higher impedance (which actually lowers the treble) but it's a tiny difference. I was trying to swap the cables without disturbing the IEM in the coupler as even a slight difference in insertion actually makes a big difference in the graph. So I did the Xinhs first and then only barely connected the stock one, I thought it might have been from it being a loose connection. This is actually what prompted me to check it with the impedance adapters (easier to swap them and get consistent measurements as they are not on the IEM end.) But either way... not a huge difference and yes, more conductivity with this if you have the bad one is a negative. Although yours doesn't seem as bright.Just to be clear: my sample doesn’t have the black mesh, but also doesn’t have the nasty high-frequency lift. So the two aren’t linked, but KZ may well have made another change that isn’t visually obvious.
The measurements I made (and all my listening so far) were done using the rather thin stock cable. I thought about buying the chunky 784-core cable on the grounds that less cable resistance is better, but the impedance adapter measurements make me think that might actually not be a good idea.
Yeah, given that the cable’s only 1.2m long I suppose you aren’t going to see much change in impedance. But I really don’t like an elevated upper octave, so I’ll stick with the twisty stock one.Stock might be slightly higher impedance (which actually lowers the treble) but it's a tiny difference.
I want the exact opposite actually. But braided cables are nicer from a usability aspect and the 784 is only £12 inc tax, which is why I was about to buy it.What a waste of copper, you could instead twist on some miniaturized resistors in an adapter plug, if this is the avenue you are considering.
Cables have their purpose, resistance addition has a different purpose. Anywhere where they intersect will either 1. have a tiny effect, or 2. make the cable ridiculously overdimensioned. Only unless the cable maker did something clever...I want the exact opposite actually. But braided cables are nicer from a usability aspect and the 784 is only £12 inc tax, which is why I was about to buy it.
Rubidium is a group 1 alkali metal similar to Sodium and Potassium, ie very low melting point, highly reactive and non magnetic and would not form any stable alloy. The googled article has Rubidium in its title and first few paragraphs. In a reading of the main article there is no mention of Rubidium but Dysprosium and other rare transition metals that do have magnetic properties, I suggest that there has been some confusion in translating from the Chinese and an erroneous text substitution was made. Interested Chemist/Metallurgist.The rubindum magnets are a fairly new thing as far as i can tell. Wonder how they will progate though the industry. Seems that only Chinese firms currently use it as it's a Chinese invention , here's the patent info for anyone whos intrested.
CN102832038A - Production technology of rubidium iron boron permanent magnet - Google Patents
The invention relates to a production technology of rubidium iron boron permanent magnet. Due to the adoption of the production technology, the thickness of alloy reaches 0.2 to 0.4mm, the crystalline grains are fine and uniform, rich rubidium is uniformly distributed, and the problems of an...patents.google.com
KZ have changed their production methods for this model. We know of at least one change (initial run had black mesh over the driver which disappeared quite early on), but they may have made other changes as well. I ordered mine on May 12 (i.e. a couple of weeks after the initial run of sales) and there was a wait of several weeks before it shipped, so there may have been a pause as they setup a new production protocol.This set made me look at KZ, but now seeing what people are actually receiving has turned me off ever buying a KZ.
Not sure why they don't raise the price to the point they can better control the QC if that's what's needed. They would still be affordable and with a better treble tuning could still try to undercut most of the market.
The seller is in a contract is with their shipping partners, not you. Just tell them you checked out of courtesy, they said they didn't receive it, and that you want a refund, since the goods appear lost by the available information. If it's after the 90 day mark you can't raise disputes.Anyone have experience with Aliexpress support? I ordered these back in May. They gave me an estimated arrival of June 14. That date has obviously passed. Their tracking says it left from the shipping partner in Compton, CA on 5/24 on their way to USPS. USPS says they are still waiting for it. Ali support told me I need to check with usps. I haven’t, but I don’t see the point if they haven’t received it.
I just wanted to mention it without any offense, I'm 38 and I hear 15 kHz yet I understand speech with noise or reverberation much harder compared to an average person. But I hear noise floor and high frequency well.Besides the fact that above 10kHz the readings are unreliable, there's surprisingly little content in that region for most contemporary music, and anyone older than a teenager is unable to hear it anyway.
