Have UMIK-2 for measurements - ISO reco's Android app to record SPL accurately
john61ct
Looking for app recommendations to measure speakers' SPL as accurately as possible from Android using a UMIK-2
Apparently for this use case, integrating the calibration file may not be so important?
Would prefer an app that will allow logging timestamped results, ideally with user notes.
NOT looking for full EQ DRC etc measurements, I will fire up a PC and pro tools like REW for that.
Although if that's what it takes to get the best SPL accuracy, so be it.
A calibration file is definitely important if you want to measure as accurately as possible.
I'd use AudioTool or Room Acoustics Meter.
If you want something for just quick check that is good enough could just go handheld. Triplett 3550 is under $85 on amazon
Thank you, but given that I have already invested in UMIK-2, wouldn't that yield more accurate measurements?
I try to avoid buying single-purpose stuff AMAP
Not sure I'm thinking I'll get one and update
