have I to lube old tape deck?
Mantra
Europe
hi
I have 2 tape decks , bought several years ago but used really very rarely
1 Denon DRS-810
2 Sony CT 93
they work but they are noisy , the last i have used in the 95 , should i lube?
and is there a tutorial how to do just in case
thanks
It is a good idea to demagnetize the head, metal tape guides and capstan shaft. . Probe demagnetizers are inexpensive used.
If tape is moving properly, I wouldn't rush to mess with it. Clean the heads and pinch rollers instead. There should be a hundred youtube videos on that.
hi
the volume is too low ,unbelieve low and when i try to stop ,it starts to move forward
for the volume the fix is for demagnetize the head ?
and when i stop playing and it moves forward , i would like to have the remote control , tried to find an application for android but nothing
