1000mW/32Ω, I suppose.1000mV ... ?
RCA input of A50 will automatically connect to RCA output after it is turn off, which bypasses the input signal to RCA output. It will switch off this channel after A50 is turn on. Working with the power amplifier/ active speakers of whole set system, it can set the speaker muted when A50 is turn on, and resume output when A50 is turn off, which makes it conveniently.
Would appreciate the review as well. I am willing to sell my Lake People G109A just to have a nice stack with this and the D50S.If @amirm doesn't have one on the way already, I'd be open to sending mine in for review.
2200 mW @ 64 ohms via 2.5 mm BAL? Wow, I love this ampJust noticed it is available now for 170 USD.
Looks beautiful when stacked together with D50/D50S and P50.
Topping A50 @AliExpress
Topping A50 @Amazon
Specs screenshot from AliExpress page:
Note the output impedance though.2200 mW @ 64 ohms via 2.5 mm BAL? Wow, I love this amp![]()
Output impedance is one of the measurements I'm most interested in. Spec is higher than I'd like, but there's several recent examples of measured impedance coming in significantly lower than spec, like the Singxer SDA-2. I'd like to see <2 Ohms become the standard.Note the output impedance though.
It should still higher powered than the Atom, but not lower impedance. So using IEMs might not be a good idea. Even drop's description suggests driving high-impedance hps.Never knew it was released, but it appeared today on Drop, though I don't think it will be any better than the JDS Labs Atom.
https://drop.com/buy/topping-a50-headphone-amp $153
shouldn't have any issueAny thoughts on how well this a50 would work with my HifiMan HE560's? Think they run 45 ohms, wondering if too low for the a50.
Background info:
I'm new to the audiophile headphone scene & this site (so don't know what I'm doing or have vocab to describe). I've already picked up an HD650, HE560 v3, was running those with my denon avr3808ci receiver (before learning better) but it obviously wasn't sounding right. Just ordered topping d50s from drop, debating what to power those headphones with and saw this pop up. I also picked up a magni 3 last week, but for the HE560 something's just missing. Still seems a bit anemic, missing weight in the midrange. Low volume also seems unbalanced. Wondering if the amp is lacking, need tubes, or should just tweak with an EQ (I'm a bit more pragmatic than purist).
Sound I normally go in for: warmer more mellow tones. Too much high frequency just hurts my ears (prefer cello over violin for example), prefer to not overdo bass either. Music: mix of classical, older rock (think U2 Joshua Tree), and EDM.
