I’ve been wondering whether anyone has ever explored a DAC architecture in which a digital audio signal is separated into different amplitude components before conversion.
The idea is to convert each component independently using dedicated DACs, allowing even the quietest parts of the original signal to be converted at or near the DAC’s maximum output level.
After conversion, the individual analog signals would be attenuated by the appropriate amounts and recombined to reconstruct the original waveform at the desired listening level.
The goal would be to make better use of each DAC’s available dynamic range, rather than having low-level signals converted far below its full-scale output.
Could such an architecture theoretically overcome some of the signal-to-noise ratio limitations associated with conventional digital volume control?
Has this approach ever been investigated or implemented, and what fundamental technical limitations would prevent it from outperforming a conventional high-performance DAC?
This question was phrased with the help of AI because I’m from Germany, and I wanted to make sure it was worded clearly enough for others to understand exactly what I mean.
