PeterOo
There are numerous reports on ASR about clicks/crackling sound when using Airplay 2. Most thorough discussion seems to be this.
Did anybody get to the bottom of this problem with crackling/clicking noise over Airplay (2)? The solution for Airport Express seems to be a firmware downgrade and return to Airplay 1, but I get this noise on all my Airplay devices and it is driving me nuts!
You can easily hear the clicks/crackling using a test tone (e.g. Spotify 1000 Hz -10 dB). With music it is not always that apparent.
Here is an example of what it sounds like. The pattern of the clicks changes every time. Sometimes random, sometimes regular (speeding up then slowing down).
I tried devices:
Harman Kardon Citation Amp (wired or WiFi)
B&W Zeppelin Air 30-pin. Was Airplay 1 unless a FW update made it Airplay 2. Is there a way to check?
Sources:
iPad Air 3
iPhone 11
LMS on RPi4 using Airplay Bridge Plugin. Either local music or LMS signal generator. Switching 16/24 bits or the sampling frequency on the signal generator did not fix the problem.
Networks (reported signal strength always perfect):
TP-Link C3150 (Ethernet/WiFi or WiFi). Distance < 1m
Personal Hotspot on iphone 11 (connected Citation Amp and iPad). Distance between devices <1m.
Apple Airport Extreme base station (4th generation) configured as AP. Disconnecting ethernet cable to rest of network did not make a difference.
The Citation Amp has perfect playback over Spotify Connect or Bluetooth. But that excludes the use of Apple Music.
Is everybody with Airplay 2 devices (still) having this problem?
Is the only known solution reverting back to Airplay 1 devices?
I tried devices:
Sources:
iPad Air 3
iPhone 11
