Has Amirm reviewed any Shunyata research or brick house or richard gray or nordost power conditioners?
J.M.
Good morning everyone. So, I have read and heard that the shunyata research is a big player in the snake oil industry. Their receptacle. AC plugs and power cords and so on. Does anyone have any proof or evidence that this is true? The other brand is Nordorst is also a player in the game of over changing as well? Any info on them being wrong or correct? Now I have heard nothing but, good things about the brick house brand. Surge x has copied and branched off from this gentleman’s ideas I have read? Is there anything on testing or proof these are good products and they do as they state on the web site? Now lastly I have a chance to get a richard Gray power conditioner and protector. I have heard he has a great pro but, know not much about him? Is it worth it to buy this stuff? Am looking for some that cleans up a little bit of static in the back round and some modem
noise every now in then in my ac plugs. I don’t want to add or take away just deal with the problem as hand. I don’t care about any other claims of sound quality or picture qualities or black backgrounds. I want it to do its job and move out of the way if am explaining it right? I listed a few companys up on top. Amirm has done so many good things and explains his findings that I begin over some company’s false claims with no real evidence or proof.
No!
The AC plus have nothing to do with this. Usually these things are ground loops.
Let’s just track down the problem and fix it, instead of looking for fairy dust.
If you give us a good description of your setup and detailed problem description, I’m sure we can figure it out and fix it for next to nothing.
Click here:
-Then type in the brand name
-Enable "Search titles only"
-"By: amirm"
-Click "Search":
Hello,
overall products that do not prove by themselves that they are great and do not publish measurements of such product are suspect by default. It is not for you to "guess" or "measure" things. It is for them to show the proof. The more outlandish the marketing of the product is, the more the proof is required. The burden of the proof is definitively on the seller.
ASR and others have multiple measurements of cables for ex, that, as you would expect show no difference wrt an amazon basic cable. You can rinse and repeat with ac plugs, power conditioner, network switches and other fun stuff invented by the audio industry.
If the OP thinks there is a "power conditioner" that will make an audible difference to his domestic HiFi (where there are no obvious faults with the electricity supply or his config), send one to Amir for test, and we'll accept his findings. Without that - "it's all made up" (TM)
Amir has shown that competently designed audio equipment is very tolerant of poor incoming AC power quality. The example measurements shown below are from this thread:
This was the AC power waveform used for the test. Its THD+N was 18%. The IEEE recommended standard for AC power (< 1000 V) is less than 8% THD.
The highly distorted AC (which is out-of-spec per IEEE 519) had no effect on the performance of the Topping A90 headphone amplifier. Therefore, get well designed equipment and you'll have zero need for any AC power filter and/or conditioner.
For myself, when companies make outlandish and/or inexplicable claims, I assume they're lying. Under those circumstances, it's on them to explain why their new thing somehow escapes the laws of physics.
With unicorn fantasy prices for questionable products it's their burden to prove they do anything useful. Conditioning wallets doesn't count.
Then there are some tests of obvious snakeoil products. But it's too much to ask to go through a whole lot of them. These vendors will also only occasionally provide products.
It is unlikely that you actually have AC problems that are making audible noise in your gear. Amps are designed to reject and filter noise from power supplies very robustly, way more than any power filter actually does.
If you do have power problems affecting your sound somehow, maybe surges or low voltage, buying the audiophile versions of these products is still pointless. There are plenty of mainstream products that do the same job for 1/10 the money.
The fancy audiophile stuff, as others have mentioned, is a scam.
Yeah, if I actually had line noise problems, I'd first try an isolation transformer from Amazon.
Thanks for everyone’s support and help and encouragement and advice. This is why I post here because some people are light years ahead of me in terms of understanding and being honest with this topic most hifi companys like A.Q. is not. I was a fan but, in the latter years not so much. I heard a $1,0000 power conditioner and surge protector that did zero and didn’t add or take away anything from the persons system I heard it on with the biggest Parasound mono amplifiers on thick marble blocks. I know that Monster cable was one of the worst back in the day. I don't have anything that is audio Jewelry or anything but, Normal Gotham Audio cables in my system. So, Partsexpress house brand is good for 8k and 4k @ 48gb and I have had them for years and no issues what so ever.
Don't forget these. A bargain at twice the price!
From Shunyata's own website:
"APPLICATIONS
When applied as a system, the DF-SS renders a significant reduction in perceived noise and time smear, yielding improved focus, clarity, depth and spatial information.
– Static-Neutralizing Polymer
– Vibration Absorbing Compound (internally)
– Polymer Cable Suspension Bridge
– Vibration Absorbing Feet for hard surfaces
– Wide Foundation (won’t tip or fall)
– Unequaled Shunyata Build Quality"
To my mind Sunyata are totally unscrupulous BS artists. They should be in prison for peddling crap like this.
Is there any brand you prefer or Just buy one and keep moving forward.
"APPLICATIONS
Ya nice one lol. How about the green dots all over the place back in the 70’s and 80’s. A fellow diyer told me about that one. I have seen the green dots and they still sell them. lol.
Haven't looked, honestly. But if the day comes I'll study them and choose one with good isolation. Basically, if you aren't listening in the midst of heavy industry, most of that power conditioning stuff is pointless.
okay gotcha. I see a tripp lite has one for around $245.00 and has 4 plugs. That should work nicely.
What were the green dots exactly? I've referred to AI and it has suggested the following:
Yes, "green dots" were famously used by hi-fi DIYers in the 1970s, though the term could refer to two entirely different components depending on whether they were building solid-state amplifiers or speaker crossovers:
1. The "Green Dot" 2N2926 Silicon Transistor
The most prominent "green dot" in 1970s DIY audio and electronics was a specific gain-grade of the 2N2926 NPN silicon transistor.
2. "Green Dot" Radionic / Electrolytic Capacitors
In the UK and Europe, 1970s audio hobbyists building loudspeakers or repairing amplifiers frequently encountered "Green Dot" capacitors. Brands like Radionic produced non-polarized electrolytic capacitors wrapped in distinct green sleeves or featuring a green end-cap dot to signify their suitability for AC audio signals (such as speaker crossovers).
Yes, Tripplite is generally good industrial stuff.
Yes you got it. You explained it better than me. Awesome job thanks for the clarification.
