Has Accuphase fixed their balanced input issue on new E-3000/4000 integrated?
theron_day
ASR testing indicated the E-280 Accuphase had issues with their balanced input and was not recommended. Anyone know if Accusphase corrected on their new E series releases?
I have not read the review, what i know is that Accuphase historicly have inverted phase on balanced in/outputs.
But i do not know if it can effect the review also i do not know if the still invert the phase, my guess is Yes.
The issue on the reviewed unit was not with inverted phase. The balanced inputs introduced a lot of noise. If you're interested in an Accuphase then the best thing to do is just use the unbalanced input and not have to worry about it.
If you look at the catalogue for E 3000 then S/N ratio is still worse for balanced than unbalanced for whatever reason.
True - but why that?
From what I remember this is a typical difference between balanced and unbalanced inputs.
For example see these specs from Topping:
So this is not "issues" but expected behaviour. Balanced connctions are less prone to external noise, however.
Their E-5000 shows 111dB for SE and Balanced, though
Quite the contrary, the balanced input must be a tour de force of engineering. 111 dB(A) at 220 mV input equates to an EIN of -124 dBV(A). You're not doing that without a 3-opamp balanced receiver circuit using decidedly low-noise parts (say, OPA1612s) and sub-kOhm resistor values. If you want the gory details, read Douglas Self's Small Signal Audio Design.
Fun fact, a basic 1-opamp balanced receiver circuit of 40 kOhm input impedance could never achieve better than about 88.8 dB unweighted (~91 dB(A)) relative to 142 mV input, even when using an ideal noiseless opamp. So the E-3000 must already be sporting an above-average circuit topology.
And this is why (balanced) pro levels are higher than (unbalanced) consumer levels by anywhere from 6 to 18 dB. The most common balanced output circuit also sports 6 dB of gain. Why then hi-fi makers would include unity gain balanced inputs (instead of -6 dB at least) is a mystery to me, I can only attribute it to cluelessness from decades ago that has been dragged along all this time. Checkbox engineering at its finest.
