Harman curve for loudspeakers
Phorize
U.K
I’ve been pondering the harman curve this morning, or more specifically why the convention is to measure headphones with references to the harman curve, but to measure loudspeakers with reference to an ideal flat response. Perhaps for professional monitoring a flat loudspeaker response is ideal, but if Harman found that users prefer a non linear frequency response in a headphone, is there any research that suggests a similar preference for non linear frequency response in speakers and if so why is that not the reference for non professional loudspeakers?
The Harman headphone curve is the response of a flat loudspeaker (Salon2 IIRC) in a moderately reflective room (intended to be a representation of domestic listening), measured by a calibrated head-and-torso simulator that acts as a surrogate for a human listener.
my research sugests that many engeniers use a steady roll-off after 1k, too (without the bass boost), but the steepness can't be meassured because it depends on distance and how reflective the room is.
actualy this is a gap in research imo. there must be a method to actualy meassure the real brightness if you include the time domain.
the only try to do so I found is this from @jlo : http://www.ohl.to/calculators/targetcurve.php; though experience seam to suggest F2 point beeing at 1000Hz
According to the Harman targets, loudspeakers are supposed to measure flat anechoically (in a reflection-free environment).
When you place a conventional loudspeaker in a well set-up listening room, the combination of direct sound (which should be flat) and reflections will combine to produce a downward sloping response (similar to the Harman target curve for headphones).
And as @Ilkless mentioned, the Harman target curve for headphones was derived from the in-room response curve produced by a flat-measuring speaker (Revel F208 IIRC) in a well-treated room.
I also thought and hoped so in the beginning, but it isn't, it was derived by EQing the Revels first to measure flat at the listeners position (mistake #1) and then by listeners adjusting bass and treble to their liking (mistake #2) by listening to some music (mistake #3 - audios circle of confusion).
In the end fortunately by the adjustments the average listeners chose it luckily doesn't measure measure very different than the Revels without any EQ except the lower bass.
the problem with the Harman curve is that pros don't balance the music in a "well set-up listening room" but a well treated one. also the precieved brightness will not translate if your listening room doesn't match the Harman room
Not sure I understand the difference between “well set-up” and “well-treated”?
the later will have no bass boom and treated first reflection points which will alter the percieved brightness
my reasoning is the following: we shouldn't recreate the average well set-up listening room, but the average mastering engenier's room; because this is what the music has been balanced to. the problem is that (HF) curves don't seam to translate between rooms
Treated with absorption?
That makes sense, although I would expect the steady-state response to become brighter in the high frequencies as more absorption of early reflections was added, not more downward-sloping.
meassurements of 2 WDR (huge German broadcasting institution) control rooms (Schoeps mk2 mics; pretty flat).
prety bad, right? lol
but we can average those to being flatish until 1500ish and then tilting downwards
yea
you take them away from the room response, you take them away form the overall response (direct+room). that is why flat target sounds too bright, because this never happend in treated and non-equed a pro room
Do you know which monitors were used there?
Ok, I’m just having trouble following you because you say:
And then:
But, due to heavier absorption, the average mastering engineer’s room will have a brighter steady-state response than Harman’s.
FWIW, my view is that looking at the in-room response is the wrong way to go in the first place.
A speaker should measure anechoically flat with smooth dispersion. How it should measure in a particular room should be how an anechoically flat speaker with smooth dispersion measures in that room.
The good old Bob Katz target which I also use currently, flat till 1 kHz and then usually dropping around 6dB till 20 kHz.
https://www.audiosciencereview.com/...ike-to-see-reviewed.10943/page-25#post-359319
Mind you it must suit the directivity of the loudspeakers and reverberation of the room, as it can be seen from the Dynaudio example.
I tried various downward sloping cruves.
But I seem to prefer flat to 20kHz - except a 3-6 dB bass bump (depending on old and new recordings) from 20Hz to 200Hz.
I can select the 2 different bass profiles quite easily using convolution engine.
