HALS - Holographic Acoustic Loudspeaker Scanner
In current HALS system we see reflection on the arm, but after some absorber material it is about -20dB in the impulse response files. It will only be high frequency because large wavelength will go past the arm without care.
It is difficult to say how much that is reduced by post processing.
The simple solution I think is to experiment with different absorber types and maybe geometry to scatter reflection. But in total it is not abig concern because of the low level.
I’ve been looking a bit more closely at the difference between HALS and the Klippel NFS approach, especially the Klippel papers and patent DE102013000684B3.
I may be misunderstanding something, so I’d really like to hear from people familiar with the HALS mathematics or source code. I hope my news ain't old news!
The common part​
As I understand it, both HALS and Klippel use holographic field reconstruction and separate the measured field into incoming and outgoing components.
Conceptually:
Measured field = incoming + outgoing
So HALS already goes well beyond simple time-gating or just “removing room reflections.”
The interesting part: secondary outgoing sound​
The problem gets more interesting when a reflection interacts with the DUT.
For example:
DUT → room/reflector → microphone
is relatively straightforward. The reflected wave arrives at the measurement surface as an incoming wave.
But consider:
DUT → robot/reflector → DUT → microphone
The reflected wave first comes back toward the DUT. After interacting with the DUT, it generates a new wave travelling outward toward the microphone.
At the measurement surface, that second wave is therefore outgoing.
So a simple incoming/outgoing separation may not be enough to distinguish it from the primary radiation of the DUT.
This seems to be where the Klippel patent introduces the idea of Primary Sound Field Separation (PSFS) — separating the desired primary sound from secondary sound generated when external sound interacts with the DUT.
Why the robot could matter​
A distant room reflection may have travelled a relatively long path before reaching the DUT again, so its level can be considerably lower.
A nearby robot structure is different:
DUT → robot → DUT → microphone
The robot can be much closer, so the reflected energy may be stronger. And after the second interaction with the DUT, that energy becomes an outgoing wave.
That makes this case particularly interesting.
A simple experiment​
There may actually be a fairly simple way to test whether this distinction is real.
Use the same DUT, same scanner and same measurement procedure, but measure it in two rooms:
one relatively small room and one significantly larger room.
If the secondary-reflection mechanism is real, we should expect the smaller room to produce stronger reflected energy because the reflecting surfaces are closer.
The difference might be small, but it should still be measurable.
And importantly, if some of that difference remains in the outgoing field after incoming/outgoing separation, that would be interesting evidence that we are dealing with a secondary outgoing component rather than simply an incoming room reflection.
Of course, room modes and absorption would also have to be controlled as much as possible.
One possible additional layer​
This also makes me wonder whether there could be value in an additional acoustic-modeling layer after the field-separation process.
Not necessarily to replace the measurement-based separation, but to predict or validate residual effects using things such as:
  • robot geometry and its position relative to the DUT
  • DUT geometry
  • the measured or known directivity of the loudspeaker
  • reflection/scattering characteristics of the robot
  • room geometry
  • possible reflection paths
A numerical model, perhaps FEM/BEM or another suitable method, could then be used mainly as a validation or residual-error model.
So conceptually:
Incoming/outgoing separation→ Primary/secondary sound separation→ robot/environment acoustic modelling
I think the last part could be especially interesting for the robot → DUT → microphone path.
My main question​
Is this interpretation correct?
Does HALS already perform the fundamental incoming/outgoing field separation, while the Klippel PSFS approach adds another level aimed at separating primary DUT radiation from secondary outgoing radiation caused by external sound interacting with the DUT?
And has anyone already investigated this in HALS, particularly the:
case, rather than just:
DUT → room → microphone?
I think this could be a pretty interesting limitation to investigate experimentally.
Yeah, I think so.
HALS part is correct. I think Klippel part is also correct.
No, but I did do a test 2 years back in a barn to have a larger reflection free time:
But unfortunately I had a lot of reliability problems. Fortunately Jan made a new design and his setup has proven to be very reliable. But no barn measurements have been done. I've retired my prototype and would need to build Jan's setup before I can do measurements again.
For:
dut -> room -> dut -> mic
Yes correct I think.
But for scanner body it is a little different again because it moves with the microphone. Unlike a room that stays the same while the scanner moves.
So scanner can reflect dut -> scanner-> mic. This should be incoming wave, but it is moving so the field is changing, so I am unsure how well it will be seperated as incoming.
For dut -> scanner -> dut -> mic there is another layer as you already described.
The good news is, the larger wavelengths will pass around the scanner body easily. Short wavelengths could be well absorbed or scattered by added materials.
I think this is actually fine tuning. At this stage I am more interested to know the existing workflow is good for how people will use it. Yesterday just found a bug with a new optimization I added, so having stable release is still the focus.
I should also say that recently I feel less fun from this project. It has been a long time I guess the excitement and energy for it is growing less. Other things in my life are also getting more important (like my new baby). So I hope to get a stable software and take a 'back seat'.
For:
Thanks for the great work you’ve put into HALS! I completely understand your priorities changing. I have a ten-month-old son myself, so I know how much life changes with a little one! Congratulations, and I wish you and your family lots of happiness. :-)
One idea for the future: it would be great if users could measure the drivers they already own using a common, standardized protocol, ideally with both HALS and a reference system like Klippel NFS. We could then share the results in a common database and gradually build a much larger collection of reference measurements to validate HALS across different drivers and setups.
I have several hundred drivers from different brands in my own lab, so I could contribute quite a few measurements to such an effort.
Of course, getting a stable release comes first. I just think this could be a great community project down the road. Thanks again for making HALS available to everyone, and I hope you get to enjoy more time with your family while knowing you’ve created something really valuable for the community!
If you ever need help with software development, feel free to reach out. I have experience in low latency programming, particularly in developing high performance math libraries. Over the past three years, I have been developing one of the fastest x86 FFT libraries available.(completely open source, MIT license)
If you need some help on a project, I’d be happy to contribute for free. We can discuss the details and see if my experience could be useful.
Have you by any chance been busy?
A significant improvement that was in the making for quite some time is finally released to the public:
https://github.com/TomKamphuys/NFS/releases/tag/v0.4.1
25/10/26
Major release with significant improvements to motion safety, speed, and user experience.
Added FastCylindricalMeasurementMotionManager: a faster motion manager for cylindrical
scans that moves radial, angular and vertical axes simultaneously (single G0) for most
moves, performing safe evasive maneuvers only when the path crosses the interior of the
measurement grid. This reduces scan time by approximately 61% (~2.6x faster) while
maintaining the safety invariant that the microphone arm never travels through the
protected volume. See docs/fast_cylindrical_motion.md for details.
For an actual measurement set including the sweep measurement 'overhead', we see a >30% reduction in the time it takes for a measurements set.
Added no-fly zone support with configurable unsafe-point policies ("abort" and "skip")
enforced by motion managers. The protected interior volume is validated against all
movement paths, not just destinations, ensuring collision-free trajectories throughout
a scan.
Added DUT (Device Under Test) volume validation before motion preview and measurement
start. The speaker geometry is checked against the measurement grid to prevent
configurations where the DUT intersects the scanning path.
This is a biggy. Previously the safety of the DUT was guaranteed by a very conservative motion manager. The FastCylindricalMotionManager still makes sure all moves are safe and falls back to a more elaborate evasive move when needed, but it is also actually checked by an independent no-fly zone checker.
For this, the GUI was changed a bit:
A dedicated DUT volume section was added that sets the no-fly zone and can be used in the measurement point grid. The values in the latter can be slaved to the DUT volume.
A motion preview can be viewed:
This will clearly indicate when a measurement, or a move to a measurement will violate the no-fly zone. This check will also be done just before a measurement set. This check uses the actual motion manager to do a virtual measurement set and records the virtual motion.
The software can be configured to handle these problematic points in two ways.
  • Ignore that point only and continue
  • Abort the measurement.
Added elapsed time estimation for measurement sets, displayed in the GUI.
Improved the GUI with no-fly zone configuration and visualization, jog button sizing
and layout responsiveness, and synchronized frame widths.
Added comprehensive type hints across the nfs package for better IDE support and
static analysis.
Added volume property to CylindricalPosition for cylindrical volume calculation.
Ps. There was a small problem with the v0.4.0 and quick fix v0.4.1 was created. Therefor this post links to v0.4.1, but describes v0.4.0 with all the important changes.
