HALS - Holographic Acoustic Loudspeaker Scanner
A US patent Klippel have for their NFS is US9584939 (e.g. at https://www.freepatentsonline.com/9584939.html). A quick search for "Klippel GmbH" as patent assignee did not show anything else that was apparently relevant (but really, really don't take my word for this).
Neither of the two claims of the patent are about the mechanical design of the scanner. This is merely shown as part of a preferred embodiment of the invention. So I consider it highly unlikely that the open source scanner robot itself is legally problematic.
The claims do describe a system for the recording and analysis of the sound field. I am way to unfamiliar with what the NFS and the open source alternative do, but there may well be patent issues here. At the face of it completely separate scanner hardware and analysis software should not be in violation, but with the software used to control the hardware there may not be a clear enough distinction (maybe separate the hardware control and analysis into separate software packages?).
I am not a lawyer (though I do have a German law degree and worked a bit on US patent applications for software implemented user interfaces, an entirely unrelated field) but I would strongly suggest that the project take a closer look at the above patent and search for potentially others, including in other jurisdictions. The possibility that public distribution of this could be a patent violation cannot be trivially excluded.
Congratulations are in order! This is an impressive accomplishment.
That said, and at the risk of taking the air out of your sail, do you know if you are clear of any patents Klippel may have in this regard? I ask because the original threads we had here proposed very different approaches to mechanics of the robot. Here though, what you are showing remarkably similar to Klippel NFS. Individuals making the device and using it purely for personal application is likely fine. But if they use it commercially in any manner (e.g. reviews), or sites hosting it, may be problematic. I know I don't want to be at the receiving end of a "take down" notice from Klippel especially when some of us have so extensively benefited from their commercial product.
Thank you for congratulations Amir.
Your concern is valid and we 'HALS team' will take some time to consider it carefully.
I will ask that users withhold from sharing general opinions about this topic because, we can all have options.
My two cents: We utilize a near-field antenna measurement system that strongly mirrors the physical appearance, operation, and mathematical principles of near-field loudspeaker scanners. In both domains, the mechanical setup includes an automated robotic boom moving a sensor—in our case, a probe connected to a vector network analyzer—around the antenna aperture to sample the amplitude and phase of the radiated field. The mathematics used to project near-field data to the far-field are functionally identical. While systems like the Klippel scanner have enabled loudspeaker measurements in non-anechoic rooms, these acoustic methods heavily borrowed from the RF and antenna arena. Historically, near-field antenna characterization systems—pioneered for example by NIST in the 60s (https://www.nist.gov/image/nearfieldlabjpg) —predated these commercial acoustic equivalents by several decades. Consequently, significant prior art regarding both the hardware and mathematical transformations existed in the RF and radar patents long before the commercialization and patenting of modern acoustic scanners.
As far as I know you are probably right about the prior art, but when it comes to patents (at least in the US) the most relevant thing is not whether the patent is vulnerable to challenge or even valid in the first place, but whether the patent owner decides to take action against you, as win or lose the process is very expensive.
Anyway I think we should respect @d.fapinov's request to refrain from commenting on the patent question, as we may all contribute quite a lot but of questionable value to the people with something at stake. It's hard to resist for me too! :)
Not in the USA, the US Patent Law make it illegal to copy a patented device even for personal use. There have been exceptions if you suing for invalidity to show it does not meet its claims.
Not in the USA, the US Patent Law make it illegal to even copy a patented device even for personal use. There have been exceptions if you suing for invalidity to show it does not meet its claims.
I was making a practical statement that a company is unlikely to go after someone's DIY build in their home/garage. PR and actual costs typically far outweigh the benefit. That's why I said probably fine. But you are right and you never know if a company wants to make an example of someone like the record companies did with music piracy.
I’ve spent time looking into the patents associated with the NFS and comparing them with how HALS works.
I found a patent family covering:
USA
Germany
China
I haven’t found NFS patents for other regions.
For the USA and German patents, I found significant differences between what the independent claims require and what HALS actually does. Based on that, I do not currently believe HALS fulfils the requirements needed for infringement under the claims’ exact wording. This is my technical assessment, rather than a legal opinion.
I’m less comfortable drawing a conclusion about the Chinese patent. I had to rely on translation, and I’d want someone qualified to clarify its technical meaning.
USA
Germany
China
I’m less comfortable drawing a conclusion about the Chinese patent. I had to rely on translation, and I’d want someone familiar with the original wording to clarify its technical meaning.
Not sure if you are aware so just a mention. US allows method, as well as, apparatus claims and EU disallows method and only excepts apparatus claims.
What I'm gathering is that the patent system is broken as is IP. Got it.
The EPO generally allows method claims, so long as the technical character requirement is met. There are some broad prohibitions against methods of treatment in the pharma space, but I don't see that applying here. Can you put a finer point on your thought about method claims? Or are we talking past each other and this is a nuance of a particular national patent office? If so, I'd love to know which one(s).
It's too long to scroll... :-)
I’ve been looking a little bit into the patent/prior-art discussion around Klippel NFS and HALS. I’m not a patent guy at all, so please don’t take this as a legal opinion. I’m just an engineer and I got curious about how old some of these ideas actually are, so I started searching aroud a little.I
And honestly, I found some pretty interesting stuff.
For example, the whole idea of representing an acoustic field using spherical harmonics and spherical Hankel functions is definitely not something that started with Klippel.
One of the papers I found is Weinreich & Arnold, 1980, “Method for measuring acoustic radiation fields”, JASA 68(2), 404–411.
This is quite interesting because they were already working with acoustic radiation fields, measurements on spherical surfaces, spherical harmonics and spherical Hankel functions. The Klippel patent itself actually cites this paper in its background section.
Then there is the Nearfield Acoustic Holography work from the 1980s.
Maynard, Williams & Lee, 1985, “Nearfield acoustic holography: I. Theory of generalized holography and the development of NAH”.
The basic idea there is already very familiar: measure the complex acoustic field close to the source and then use mathematical methods to reconstruct/propagate the field to other positions.
I also found some older work by Williams and others on automated nearfield acoustic holography.
There is a 1985 paper about an underwater automated scanner where a computer controlled mechanical system moves a hydrophone around the object and samples the acoustic field.
So basically:
mechanical scanner + acoustic sensor + spatial measurements + mathematical reconstruction
was already a thing quite a long time ago.
There is also work from around 1987 on generalized NAH for cylindrical geometry, where the 3D sound field is reconstructed from measurements on a cylindrical surface.
Again, that made me think about the whole “cylindrical scanning surface” concept used in modern loudspeaker scanners.
Obviously none of this means “Klippel copied it” or that a Klippel patent is invalid. I’m not saying that at all. I really don’t know enough about patent law to make that statement.
What I’m trying to understand is where the actual patentable part starts.
Because things like:
  • Helmholtz / wave equation
  • spherical harmonics
  • Hankel functions
  • nearfield acoustic holography
  • acoustic field reconstruvtion
  • cylindrical or spherical measurement surfaces
  • automated spatial scanning
are clearly based on much older academic work.
And even Klippel's own patent seems to acknowledge a lot of this prior work in the background section.
So maybe the important part of the Klippel patents is not “we invented a robot that moves a microphone around a loudspeaker” or “we invented acoustic field reconstruction”.
Maybe the actual invention is the particular combination/workflow of these things, for example how the measurement surface is defined, how the direct sound is separated from room reflections, how the coefficients are calculated, how the field is extrapolated, and how all of this is implemented together in a practical loudspeaker measurement system.
That distinction is what I’m trying to figure out.
I also found it interesting that Klippel's own historical material mentions earlier work by people like Don Keele and Weinreich, so even Klippel presents this as an evolution of previous acoustic research rather than something that suddenly appeared from nowhere.
Again, I’m not claiming I discovered some secret prior art or that Klippel has no valid patents. I’m just sharing what I found while digging into the subject.
If somebody here actually has experience with patents, I’d be really interested to hear their opinion on this.
Especially the difference between:
prior art for the underlying acoustic/mathematical method
and
prior art that actually affects the specific claims of a particular Klippel patent.
I think those are two quite different questions, and I may be mixing them up a little bit.
That's great news. But just to be clear, do you account for secondary reflections from the surface of the speaker? And if so, how?
Amir, I think there’s a small distinction here.
When the HALS developer says “No, HALS does not do that”, I don’t think it means HALS ignores baffle/cabinet effects. Those effects are naturally part of the measured outgoing field.
What HALS apparently does not do is physically separate that field into things like direct diaphragm radiation vs. baffle reflection/diffraction, cabinet scattering, horn modes, etc. It basically separates the outgoing field from the DUT from incoming/external fields such as room reflextions.
As far as I understand, NFS works on a similar principle. Klippel does have additional processing for things like baffle diffraction in some configurations, but that’s still different from physically identifying every secondary source inside the loudspeaker. So I think the key distinction is: measuring the total effect of the speaker surfaces vs. actually modelling/identifying each physical source of that effect.
Just my $0.02 ;-)
You are correct, Amir.
To the forum, Amir has a very reasonable expectation that he is not hosting something which could bring trouble to his door.
Past that, please can we keep this discussion about HALS itself, rather than discussion about patents, IP and similar topics?
Thank you.
That's not the effect we are talking about.
The radiation from the speaker hits a reflective surface and then comes back to the surface of the speaker, mixing with its direct sound. Klippel has mitigation for this 'secondary' reflection. HALS does not. It is a minor effect though as reflection has gotten quite a bit weaker than the speaker output assuming the reflecting surface is not too close.
I will defer to a patent lawyer. I am an listed as an inventor on 110 patents on medical devices mostly for the cardiovascular system and written many a specification but what has been claimed has been the legal parlance of the IP attorney. It may be that med devices has some of same treatment as pharma, not sure. I did not review the the IP in this thread.
Since this thread is about HALS, I think it is also a good place to discuss some technical details about the current HALS implementation, and maybe also some possible upgrades for the future.
Amir, it would be really great if you could read this when you have time and give me your thoughts. I know this post is a little long, but this question is quite important for me, and I think it may also be interesting for others working on HALS/NFS.
I looked a little more into this and I think I understand the point better now.
From what I can see, Klippel NFS is not only using time gating for reflections. At higher frequencies they can use time windowing, but at lower frequencies they use input/output field separation with two scanning surfaces. So they can separate the outgoing field from the incoming field caused by room reflections and other secondary sources. But I am still not sure about the specific problem you mentioned, the secondary reflection from the scanner itself.
For example:
DUT ‌>>----> scanner arm >>----> DUT >>----> microphone
In this case the reflected sound comes back to the DUT and then the DUT radiates it again. So after that, it may look like a normal outgoing wave from the DUT. I am not sure if normal field separation can remove this.
I couldn't find in the public Klippel documentation if they actually model the 3D geometry of the scanner for this, or if they mainly design the scanner so these reflections are very small and negligible.
Also, as far as I understand, current HALS already has the incoming/outgoing field separation. But I haven't seen a model in HALS that includes the actual scanner geometry and its scattering.
This makes me wonder if we could do something more with a DIY scanner.
Since the robot always knows its exact R/Z/Phi position, maybe we could include the scanner geometry and position in the acoustic model, together with the measured directivity of the DUT. So the scanner would not be treated as completly invisible, but as a known acoustic object.
Maybe this is too complicated, I don't know. But I think it could be an interesting way to go beyond the normal field separation.
So my main question is: Does Klippel actually do something special to deal with Scanner >>----> DUT >>----> Microphone reflections, or is the scanner simply designed to make these reflections negligible?
If anyone knows more about this part, I would be very interested to understand it.
