magconpres
- Joined
- Feb 28, 2021
- Messages
- 4
- Likes
- 0
HI,
I have a Haffler DH-220 that operates find but sound a bit tired/lackluster. I got if for $150 a year ago and just through it into service. I'm thinking it's time to do some upgrades for it.
Some background on me and my skills. I understand basic electronics pretty well. I've done some HAM radio mods and do a lot of circuit building with micro-controllers, but audio is new to me, other than building a headphone app from a design on-line. Soldering skills are good. Workbench is pretty good with a temp controlled soldering iron and a Tek O-scope and a plethora of multiple meters from freebies from Harbor Freight to a Fluke benchtop.
I read Puprasmart's DH-220 Rebuild thread and found lots of interesting stuff in there.
So, my questions....
I have about $500 budgeted for the upgrade. I was leaning towards the Musical Concepts boards...either the PA6 or PA7s (hadn't decided).
For around the cost of the PA6's, I could get the Corbell designed boards mentioned in Purpasmart's thread.
Does anyone have any experience/recommendations/thoughts about one board vs the other? My thought's are that getting the Corbell based board's and buying my own components direct from Mouser is a better deal as I won't pay MC's markup on the components. But if the MC boards are better, maybe it's worth the price?
My second question is more about where to start. With the PA6's or the Corbell boards, I could likely upgrade the power supply at the same time (including new boards, considering the dual mono set up from MC). that's a bot of stretch on the budget, but not much
I think if I went with the PA7 boards, I likely couldn't even get new PS caps right now as looking at prices, a pair looks to be over $100.
Or, I could just gets some new PS caps for now and call it good till I have more cash.
Bottom line...I'm a bit stuck on where to start and what path to follow. I'm OK doing this in stages, but would like to have an end state in mind before I start so I don't buy things that I won't need/use in the end.
Thanks,
James
Thanks,
James
