...it belongsAlso nice that they hid the MQA logo around the back where
if noone has mentioned it, not importy, but Dynamic range says X16 in pic...Oops. Just went to bed. Will add tomorrow. It was exceptionally clean.
I'm sorry to ask, but when I reply does it include the article as it appears that it is going to as I post? So I guess this is a test.This is a review and detailed measurements of the Gustard X18 Balanced USB DAC with Bluetooth. It was sent to me by their seller, Shenzhenaudio and costs US $749.
As you see style is very much the same as other Gustard products. I like the high resolution display with larger volume indicator.
Back panel shows the usual connections:
Gustard X18 Measurements
Let's start with our usual dashboard with balanced output with digital input adjusted by -2 dB to get nominal 4 volt output:
That is extremely good performance. The second harmonic dominates distortion profile but it is down -135 dB (25 dB below threshold of hearing). This easily qualifies X18 as state-of-the-art, placing it in top 3 DACs ever measured:
Switching to unbalanced RCA output, we still get superb performance:
Allowing the output to get up to 5.4 volt, we get even better performance due to increased dynamic range:
Dynamic range is exceptional:
Intermodulation+noise performance is superb as expected:
Jitter test over USB is great:
But there is some inconsequential jitter components if you use Toslink or Coax:
Linearity is nailed:
As usual, you have an array of reconstruction filters to choose from:
Using default L-FAST, we get extremely clean wideband distortion+noise performance:
I live for happy days like this: another instrument grade, exceptionally well engineered audio product in the form of X18. It is clear a ton of effort has gone into providing full transparency to input signal. Yes, the cost is up there but if you want the best, you now have one more option.
It is my pleasure to recommend the Gustard X18 DAC.
yes, it will show the article but it will be non-expanded and without pics i believe, so not a biggy. second option: highlight with your mouse the text you want to replay TO, it will show a replay icon and click on that..Do I remove the article from my post as it is automatically picked up. Sorry for the ignorance.
I am not exactly sure what you mean by “stability,” but if you mean longevity of the company (ie, will they be around next year or are they a just a flash in the pan), Topping has been in existence for quite a while. I remember Parts Express selling Topping amps based on the Tripath chips when they were all the rage 10-15 years ago.
OK, thanks.yes, it will show the article but it will be non-expanded and without pics i believe, so not a biggy. second option: highlight with your mouse the text you want to replay TO, it will show a replay icon and click on that..
@196Khz is unusual?Multitone added to the review.
Maybe its time for Gustard, SMSL or Topping to release something terrible, just to spice things up because right now its getting boring.
i believe smsl su-9 has it? or close enough 192Khz i think...Lovely, but my next DAC should have Lossless Bluetooth.
I was told Snapdragon 8 Gen 1 will be the first chip offering it...i believe smsl su-9 has it? or close enough 192Khz i think...
It is the way this sample multitone came from AP so I have been using it such to get some coverage of higher sample rates.@196Khz is unusual?
not that i don't like it. just wondering why.
What high voltage output?looks great, where's the high voltage output tho?
Yes. So it is better to not quote it.I'm sorry to ask, but when I reply does it include the article as it appears that it is going to as I post? So I guess this is a test.
A mains voltage output to power an amp, perhaps?What high voltage output?
Thanks. Will fix later.if noone has mentioned it, not importy, but Dynamic range says X16 in pic...
