Please share testing firmware again. I tried the GitHub TIDAL Connect on your Gustard R26 method but I can't connect via ssh, Gustard asks for root password. So only you can help.![]()
R26_Test_TdCnct
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.www.mediafire.com
You try sudo ?Please share testing firmware again. I tried the GitHub TIDAL Connect on your Gustard R26 method but I can't connect via ssh, Gustard asks for root password. So only you can help.
# sudo passwd
I do not have the "loud pop" problem. Ahhh a friend just gave me s Dell OptiPlex 7070 which I can just use the same dock as my mac and play music from PC. However, i have not touched a PC or decades so I don't even know what player to download for my collection of DSD, WAV and FLAC files. FLAC seems to play with what came with windows but only at 48According to change log software version 1v4 for streamer part of R26 solved some loud pop at beginning of DSD playback, when you encounter such a problems you could bother to update. It is hard to give you advice about player on OSX, I'm Linux user. My good old friend uses OSX and now experiments with HQ player and Roon. Source is Tidal. For local files playback can be HQ player good choice especially if you are after EQ or other sound modification.
I don't use Windows, but HQplayer may be good choice for playing DSD, but it is not cheap.I do not have the "loud pop" problem. Ahhh a friend just gave me s Dell OptiPlex 7070 which I can just use the same dock as my mac and play music from PC. However, i have not touched a PC or decades so I don't even know what player to download for my collection of DSD, WAV and FLAC files. FLAC seems to play with what came with windows but only at 48
Thank you once again! I appreciate you taking time to reply me as I am a complete dummy.I don't use Windows, but HQplayer may be good choice for playing DSD, but it is not cheap.There should be some free options too.
HQplayer is good for more advanced processing aka. resampling and/or EQing. Try Foobar2000, it is free and may suit your needs.Thank you once again! I appreciate you taking time to reply me as I am a complete dummy.
I will be staying with iOS for now. Someone has recommended that I stream from Qobuz abd use Roon for LAN connection with the R26. All these are a lot fr me to grasp.HQplayer is good for more advanced processing aka. resampling and/or EQing. Try Foobar2000, it is free and may suit your needs.
What you prefer about x26pro. I ll like to change my smsl su-9 for x26proI've returned my R26. Sound was not as good as X26pro.
To my ears X26Pro is more transparent with more resolution and fine details. But I think I'm negatively biased by R26 not so good multitone measuremnt that is on the edge with 16bit resolution, I'm only human and cant hear distortion/difference between 16bit resolution and 21bit of the X26pro, right?What you prefer about x26pro. I ll like to change my smsl su-9 for x26pro
Yes we are all human,To my ears X26Pro is more transparent with more resolution and fine details. But I think I'm negatively biased by R26 not so good multitone measuremnt that is on the edge with 16bit resolution, I only human and cant hear distortion/difference between 16bit resolution and 21bit of the X26pro, right?![]()
You need to inject ssh key to device first, Gustard will not tell you root password I think!I received my A26 today but I can't see it with a USB-C cable. I have tried 2 cables. On the network I have Gustard and ssh but I don't know the root password... so I'm a bit stuck to explore.
Have you tried another USB cable? For me second one worked...I tried everything on my win10 laptop... on a winPE Serguei key, booting on an Ubuntu key... impossible to "see" the A26 card.
Under W10, I have "unknown device" and under Ubuntu... Nothing, only the laptop disk and the boot key (/dev/sda, /dev/sdb).
I'm not sure if I'm going to be able to do this, but I'm not sure I'm going to be able to do it.
In conclusion, I'm not ready to switch to ssh.![]()
usb-c to usb-c cables was no go for me. I've to use old usb-c to usb 2.0 from LG V30I'm going to test with a 3rd cable (that of my Google Pixel).. but the cables seem to work (power off, the power button lights up when connected).
Do you have a reliable Gustard support email?
Are you working and connecting the Gustard under Linux ? If you are doing it under windows, can you please look at the device manager and tell me how it is recognized and with which driver? Still no connection for meusb-c to usb-c cables was no go for me. I've to use old usb-c to usb 2.0 from LG V30
Linux, sorry.Are you working and connecting the Gustard under Linux ? If you are doing it under windows, can you please look at the device manager and tell me how it is recognized and with which driver? Still no connection for me![]()
stef@raspberrypi:~ $ sudo lsusb -v -t
/: Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/4p, 5000M
ID 1d6b:0003 Linux Foundation 3.0 root hub
/: Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci_hcd/1p, 480M
ID 1d6b:0002 Linux Foundation 2.0 root hub
|__ Port 1: Dev 2, If 0, Class=Hub, Driver=hub/4p, 480M
ID 2109:3431 VIA Labs, Inc. Hub
|__ Port 4: Dev 6, If 0, Class=Hub, Driver=hub/4p, 480M
ID 1a40:0101 Terminus Technology Inc. Hub
|__ Port 3: Dev 7, If 0, Class=Vendor Specific Class, Driver=ch341, 12M
ID 1a86:7523 QinHeng Electronics CH340 serial converter
|__ Port 4: Dev 9, If 0, Class=Vendor Specific Class, Driver=, 12M
ID 1f3a:efe8 Allwinner Technology sunxi SoC OTG connector in FEL/flashing mode
