With home or prosumer equipment this is habitual, even the ADI 2 line does it, the DAC variant also has the jacks at different heights, the PRO does not because they are identical, but this is a non issue.
The problem with Gustard is that it doesn't have good distribution in many countries, you can easily buy SMSL or Topping through Amazon Prime, and personally I would spend the difference and get an A90, although it uses a regular potentiometer for volumen control.
Jacks that are used frequently have to be sturdy. My experience is that jacks soldered to the main PCB is wrongheaded. A likely point of failure. I don't know what this looks like on the inside, so I can't say. Maybe the connections are very solid. I've experienced problems in the past with jacks as part of the mother board. It is a low price point solution.
