Gustard DAC-X30
The takeaway for me from this - do not buy a $3k dac that measurably will not make a difference compared to much cheaper dacs.
If enough folks are not buying into this, perhaps manufacturers will stop making a dac with 4 dac chips and trying to bill you $3k for it...
Its really market driven, if no one buys it, they will just go back to making single dac chip and hopefully less expensive dacs
Manufacturers can of course still make ‘better’ measuring equipment and charge more for it, but customers must be aware that the extra cost almost certainly does not correlate with better sound quality.
You probably mean the SONY CDP-XA50ES CD player and not the Sony PS-X50 vinyl turntable (effectively Direct Drive with remote arm lift = complete nonsense).
Because there are several Sony ES 50 references.
To make a comparison between these two devices, you need to test their reading skills by test disc (of measurements, eh). Which does not tell us their sound, for the layman of course. The best is then to record from the digital then analog output the same tracks on a computer for example.
Then listen in abx.
Personally, when listening to music, no CD player I've ever encountered has done better than a low-end one.
When playing some demanding test discs, with very low recorded signals, you could hear more noise than music or sounds. But it was almost never the most expensive ones that won.
Some old Philips at low prices were quite remarkable. Like their IS 5021 DAC ; 104, 371 & 723 players.
I would like a detailed report then - mostly focusing on the sound quality.
Good news! They all sound the same.
A link to 492 pages of explanation, but really you only have to read the first post
My null tests show slight (but totally repeatable) differences between DACs. (Whether these are audible or not is another matter...)
Not a 'detailed' report, but...
Managed to compare the X30 to the SU-10 this morning. Setup:
A. switch -> ethernet -> sMS-200 Ultra -> USB -> SU-10 -> balanced XLR -> LA90 input 2 -> K1000
B. switch -> ethernet -> X30 -> balanced XLR -> LA90 input 3 -> K1000
Levels matched to 0.1dB using Roon's DSP (1kHz sine captured with ADC). Volume controlled by Roon (LA90 volume bypassed). All cabling identical in both cases.
And I can report that... they sound virtually identical to me. Both are truly superb, and right at the top of the pile of DACs that I currently own or have owned/heard.
However... were someone to put a gun to my head insisting I identify a difference, I'd say that the SU-10 adds the slightest 'glare/gloss' to the sound.
In any event, I didn't buy the X30 because I wanted to improve on the SU-10's sound. I bought it because I wanted a one-box streaming solution with pleasing aesthetics. For this, it is perfect.
HTH.
Mani.
The K1000s were designed to be connected to the outputs of a 'regular' speaker amp. I use banana plugs with the LA90.
But something like an A70Pro should be able to drive them, in which case you'd use its 4-pin output. (Haven't tried this.)
HTH.
Mani.
It's not that I don't believe you, but I think you let the same nonsense that "they all sound the same" influences your judgement/decision. There is a bunch here who would always try to coerce you into believing that their $200 system sounds as good as your 50K system.
No-one ‘here’ would say that, $200 - 50k dac perhaps.
They need to change the font. "FIXED" — if that's what it is — lookes like "FIXEO".
Was just about to ask what FIXEO meant?
Virtually no one said such things around here.
I'm sorry, but you do seem somewhat confused between the "all transparent DAC sound the same if properly level matched", or "all transparent amp sound the same if not under clipping conditions" ideas and your statement about the overall systems, which is pure nonsense.
"Virtually identical" doesn't mean "the same".
For one, they have very different filter implemenations, which definitely affects the way they sound. But overall, I'd say they're in the same league SQ-wise. Some might take the SU-10, but I'd take the X30.
