Update on testing. The “flawless” firmware update turned out to be a bit more complicated. Post update, the unit would power off randomly. Powering off and on - even unplugging the power cord - failed to correct this behavior. The DR70.local webpage had a “reboot” selection which I finally tried - which cured the random power off behavior. Curious that “reboot” is different than unplugging it.
Airplay, USB, optical - all work fine. Sound quality is also fine. Mechanical build is exceptional and price is reasonable. Operator’s manual needs work and should be included in box. If one desired to roll op amps, they are socketed - I wouldn’t as what is already installed is quite sufficient. The 12-18 volt DC barrel power input is somewhat interesting if one wished to use a battery or linear power supply.
Curiously, the ethernet version’s internal picture - from Gustard - does not use the power cord ground, while the version without the network connection does show the ground connection.
Both versions show CE rated on the back, so possibly falls under double insulated category. I haven’t opened mine to verify ground connection. Possibly, they had ground loop issues once ethernet was connected.
To keep or return is still not decided. It looks like I can connect both DAC’s to different USB ports on my raspberry pi 4 and switch playback destination on Volumio. Just need to make a second balanced cable for the second balanced input on my integrated to simplify comparisons.
