Davide
I studied a bit and I was able to do the math. EVAL1 has 14.6 dB gain in buffer stage and 1ET400A requires 9.6V for 1% THD at 65V supply.
Therefore, it is reasonable to use up to 1.8V at the EVAL1 input.
In the case of our A18, considering the maximum 6.35V measured by Wolf, 11 dB of attenuation are needed to get 1.8V at its XLR output (SINAD lowering is negligible as it is always higher than EVAL1).
Alternatively, however, I have seen that we can modify the gain of the EVAL1, and if I did the math correctly it would be enough to replace the 1.5k Ohm "R17" with a 2.7k Ohm one.
Unfortunately it is an SMD component so soldering is delicate to perform ...
This should be the point of having a perfectly compatible system .. if I have something wrong, please correct me.
