So I got the Cioks DC7. It's actually pretty impressive. This eliminated about 5 wall warts (DAC, ethernet switch, MiniDSP box, MiniDSP dongle, something else too). There are 7 adjustable voltage outputs , 660ma at 12v, plus USB. 660ma not enough? The outlets can be paralleled. I used 3 for about 2a for my DAC. The RCA outputs are a great feature IMO, allowing for easy extenders, Y connection etc. Get some of those adapter things and you do whatever you want.
So how does it work? Were the wall warts injecting deadly interference into my power lines? Were they modulating or polluting the delicate ethernet bits and jittering everything? Or something even worse? Maybe I was even being deprived of blacker blacks and dulled sprinkles! I like measurements, but what to measure? And, depending what's measured , is it audible anyway? Nobody seems to have much of protocol for this stuff, so I just took a blunt axe to it: can I detect any change in audible room noise making it through the system after replacing wall warts?
1. All electronics on using wall warts
Note the bend in the HF noise. Also, the 8k spike is some mysterious, intermittent effect that I can't localize, but should be ignored.
2. All electronics on using DC7. Note smooth bend at 7kHz.
So, does look like the DC7 actually IS doing something to the room noise floor at the high end. Is this the blacker blacks? I have no idea. In my highly subjective, uncontrolled listening test I couldn't hear any differeence whatever. I guess this shouldn't be too surprising since whatever we're looking at is orders of magnitude below anything that might be playing, even playing at low levels. So is this worth the $$$ and trouble? Well, I got rid of a bunch of PITA wall warts, improved system engineering, and the whole affair now let's me sleep better. YMMV.
Cheers,
