YouDontHaveEnoughBass
- Joined
- Feb 13, 2026
- Messages
- 142
- Likes
- 201
Works brilliantly thanks!
Better resample the filters in SoX. The command should be something like:Hello. I want to use Gsonic filters with Volumio and the FusionDSP (CamillaDSP) plugin. However, this requires filters for every sample rate—44.1, 48, 88, 96, and 192 kHz. So, I have a question: is it better to buy the UMIK-2 (44–192 kHz) right away and create filters in Gsonic for each sample rate by adjusting the device settings in the Windows Control Panel? Or should I use the UMIK-1, import the 48 kHz file into REW, and then export it at 44.1, 88, etc., kHz? Of course, I know I could just resample everything to 48 kHz within Volumio, but I’d rather not...![]()
You can use Audyssey mic if your PC has a sound card (a mic calibration file for it is linked under GSonic Immersive video description) but the filters work on PC where you would be playing your music sources from.Noobie question: Does this run the same as Evo 1 Acoustics? Audyssey microphone plugged into AVR, start it and let it do its thing, and results are sent to AVR?
A processor will need to convolve 32k FIR taps continuously with the the played content.Since I do not necessarily play from PC, can GSonic Reference be used "globally" in passthrough mode?
Sorry for my ignorance, bad question. Gemini reminded me that GSonic Reference does not include any convolver, just for measuring, filter creation and export.A processor will need to convolve 32k FIR taps continuously with the played content
If playback is only coming from a PC, running the convolution directly on the PC (via Equalizer APO, Roon, JRiver, CamillaDSP or HQPlayer) is zero-cost, lower latency, and simpler.Sorry for my ignorance, bad question. Gemini reminded me that GSonic Reference does not include any convolver, just for measuring, filter creation and export.
I plan to use rPi5 as processor, downstream of PC playback (if any). Any disadvantage there wrt GSonic Reference?
How about between HLC vs CamillaDSP as processor
How about between HLC vs CamillaDSP as processor?
HLC's convenient ability to A/B filters is like a flashlight in the dark.How about between HLC vs CamillaDSP as processor
RPi will do everything. Make it a playback source. Windows and Mac and iPhone and Android can play to it using AirPlay DLNA whatnot. That is how my set up is. RPi runs the filters and EQ using CamillaDSP. I AirPlay to it. I have mine set to AirPlay 1 so it is always CD quality and never negotiates to lesser streams. CD quality is all you ever need. I would change it to high rez but I don't want to give up the convenience.Of course! But as I stated, a PC is only an optional and at most occasional part of my playback chain. And never windoze...
Thank you for that. Next question: Once the process is complete, how do I run the music output through my Denon 4800 AVR? Do I make this one of the presets or do I use pure direct pr something else? Thanks again.You can use Audyssey mic if your PC has a sound card (a mic calibration file for it is linked under GSonic Immersive video description) but the filters work on PC where you would be playing your music sources from.
Your AVR is just a power amp in that set up and as such should be kept pure direct/large speakers/volume-distances settings equal for FL and FR which is also what it should be set during the measurement stage.Thank you for that. Next question: Once the process is complete, how do I run the music output through my Denon 4800 AVR? Do I make this one of the presets or do I use pure direct pr something else? Thanks again.
why don't you use WiiM for EQ?
Fantastic point in favour that, tx!HLC's convenient ability to A/B filters is like a flashlight in the dark.
