So new measures are needed, or you can use an existing set of measures and generate new corrections?GSonic Reference v1.0.25 released.
Enjoy!
- Report.txt is now written next to the filters: transition frequency, speaker roll-off, stereo balance, headroom, and a band-by-band check of how left and right sum at the listening position. If your room cancels mono bass at some frequency, it shows up here.
- Bass Phase Alignment, optional and off by default (Generate > Advanced). Rotates left and right in opposite directions below 100 Hz so mono bass sums in phase at the listening position. Pure allpass, no level change, added group delay capped by a slider. In my room it filled a narrow 80 Hz null with no image shift; the audible gain was small, so try it only if the report flags a cancellation.
- Phase correction now uses a frequency-dependent window (6 cycles, 8 ms maximum) instead of a fixed 4.5 ms, so the tweeter is windowed anechoically and low crossovers get more resolution. Correction is faded where the three measurement positions disagree or inside deep notches, and whole turn phase laps through nulls are no longer treated as speaker phase.
- Bass correction is designed with a 2 Hz minimum bandwidth so the 32768-tap filter reproduces it exactly. Previously the narrowest cuts could be off by up to 1.5 dB after export.
- Exported filters never exceed 0 dB at any frequency. Heavily limited tracks may still need a couple of dB of headroom in the convolver, as before, by design.
- Sub-sample alignment of the spatial average had its sign reversed; fixed. Small effect on treble phase only.
- The measurement prompt now suggests placing the two side positions about an ear's width from MLP.
