I was busy with home renovations this last year and now that we have moved, I am getting back into things and need to re-calibrate my theater and am wondering which rabbit trail to follow.
Here is my setup and goals:
Usage: Pretty evenly between video games, movies, and music (via laptop).
6.2.4 setup (phantom center) with additional tactile setup with: HoverEZe and BossBack
Amp: Denon AVR X4400H
L+R amp (connected to the pre outs on the reviewer): 3e Audio A7
Subwoofer amp: Behringer NX3000D
Tactile amp: Behringer NX3000D
Speakers:
- L+R = DIYSG HTM 12 v2
- Surrounds = Energy e-XL bookshelf speakers
- Atmos = small Sony satellite speakers
- Subs = Two Mach Audio 18" subs in two Marty Cubes
- Tactile = HoverEZe (bass shaker with two 18" subs under the couch) and a BossBack (very near field open baffle 10" subwoofer in the back of the couch
I have a Umik-1 microphone and am reasonable with using REW (although endless things to learn).
Questions:
Speaker full range correction?:
My thoughts on equalization is that I would just correct below the Schroeder frequency for all the channels but then would like to EQ full range for the HTM 12s as they have outstanding directivity and klippel measurements (
https://www.erinsaudiocorner.com/loudspeakers/diysg_htm12v2/) that show room for improvement with the primary frequency response and thus are prime speakers for full range EQ. I would be happy to manually do the high frequency EQ as I have done that before (
https://www.audiosciencereview.com/...m-gated-nearfield-klippel-measurements.24533/) but I don't know how to add that to the EQ file (is it a ady file?) that would be generated from one of the EQ programs.
Subwoofer / Tactile Response Questions:
My second question is how to best manage the 2 subwoofers and 2 Tactile sub systems?
Currently, I have Sub 1 output going to a Behringer amp that goes to two independent 18" subs and Sub 2 output goes to a Behringer amp for the HoverEZe and back sub.
Should I keep it the way it is and then manually align the 2 subwoofers as a group and if so what's the best stepwise process for this (as it's been a while since I did this and I think I used acoustic timing references and REW to phase align them to get the ideal distances)?
Then should I use the eq capabilities of the Behringer to take down major peaks and then use whatever eq solution to do the granular details? Or should I fully EQ the subwoofer with REW and the Behringers 8 eq filters (as I am comfortable with this and done this in the past) and then run the EQ program as the final layer? Or should I leave it all to the EQ program to eq the subs one time aligned?
I guess an alternative thought I had was to use each subwoofer outputs for each 18" sub and then I could use whatever EQ program to deal with each of them individually. But then that leaves the question of where would I steal a signal for the Tactile subs? I was thinking I could use a Y splitter off the L+R pre outs that are already being used and then route the split signal to the Behringer amp for the tactile subs and the other signal to the 3e Audio A7 Amp for the L+R speaker. Would that degrade or compromise the signal for the L+R speakers? But then in this case I would need the L+R to be set as full range and a double bass system and ensure that whatever EQ system is used that it does not touch or alter the signal below 80hz as I would be manually looking after that time alignment and EQ of the tactile system myself after the EQ program has been done as I think the EQ program will not understand what all is going on with the tactile system and don't want it touching those frequencies.
Any other ideas where I can get a subwoofer signal for the tactile system? Or should I just keep the two subs as a group for one of the subwoofer output and then the other subwoofer output for the tactile setup?
Ok now that you have all the information and my questions.
Which EQ rabbit hole should I go down? A1 EVO AcoustiX? A1Evo MJ Custom (MJC)? +/- Should I layer on GSonic Reference at the end for laptop music listening, or just pay for GSonic Evo 32?
Thanks for any thoughts or direction as I am happy to go down a rabbit trail or two, but want to avoid going down too many of them.
Thanks again!
