I tried G Sonic Filter for 2 systems:
1. Monitor speakers: Just a pair of vintage monitor speakers from Kenwood — old, very cheap, used in my small working room. Sonos Connect Amp as the amplifier, connected to a MacBook Air M2 via ThinkPad Dock. ThinkPad Dock output is 3.5 mm, going to Sonos Connect Amp by a 3.5 mm to 2 RCA cable. I know this chain is very bad, but it's just a monitor speaker to play ambient sounds like jazz or lo-fi. Before applying the DSP, the sound was very bad. But with G Sonic Filter and CamillaDSP, it became very good compared with before.
2. Main system: KEF R3 + SVS PB-1000 sub. DAC: D90 III Discrete → Preamp: Pre90 → Power Amp: LA90D x2. I use XLR out from Pre90 to KEF R3 and RCA out to SVS PB-1000 (2 RCA L+R). I set LF on SVS sub at 85Hz, with volume and phase adjusted with REW.
Currently I measured this system with REW (UMIK-1) and applied PEQ (20–350 Hz, no boost, only cut peaks, Toole curve) for L+sub and R+sub separately on D90 III. For me, the sound is very good compared with MiniDSP Flex (with Dirac live/ both full range and limited range) or WiiM Pro Plus + SMSL D6s (Apply same PEQ on Wiim)
I tried measuring L+sub and R+sub with G Sonic and applying CamillaDSP to this system (limited range to 350 Hz, Toole curve, boost medium +6 dB), but I have to say the sound was lifeless. So I'm happy to go back to simple PEQ for my main system.
