My setup is Audy mic connected to Soundcard, and output is from PC over HDMI to AVR (SR6013), via WDM.
With Gsonic, the output levels are REALLY low, so low that I need to set volume on PC to 100%, and then also on AVR unusually high, like -15db or so, much much higher than I need to set with AcoustiX. Gsonic is also reporting "levels too hot" or something nonsensical, even if I barely hear anything when sending test noise from Gsonic.
(When I do the built-in "test" in Windows sound card control panel (where it sends chimes to speakers) it is normal, loud volume.)
That being said, I would really also have the ability to measure C and Surrounds, or as an alternative the exact settings I would need to use in REW to sweep and then export the impulses so I can convert them in GSonic. (Which in theory might work when I rename measurements and then have Gsonic produce FIR from them?)
