How does Gsonic correct the massive dip at 50 Hz on the right channel? On the other hand the minor dip around 180 Hz in the right channel seems to be mostly uncorrected.
"4 R Raw" is the uncorrected measurement and "2 R AcoustiX" is the Gsonic corrected measurement, channels are all offset.
Is it an instance where the left channel that doesn't present the same dip at 50 Hz is used to correct the right channel? Does Gsonic have any mechanism to avoid excessive excursion when it increases some bass frequencies?
Side note, did I just massively increase the headroom of my speakers considering Gsonic EQ'ed away a massive amount of bass that was due to room gain?
