Snowej
- Joined
- Aug 29, 2025
- Messages
- 8
- Likes
- 1
G'day fellas, I read through the 'has this already been discussed' threads and it has, but not necessarily in regards to my scenario.
Basically I have a PC with a high powered GPU a.k.a. RTX 3080 (might be important) with a Topping D10 DAC connected via USB (USB acts as power/data), via RCA to a XDUOO MT-602 tube amp, connected to my headphones. They're all connected to the same power strip (8 plugs). The devices connected are:
I recently purchased 4 separate noise filters/hum destroyers (I'm going crazy) from Amazon, and I've only tested one of them so far -- which DID work in removing the noise. They are all very similar, a little box with RCA input and output, some are smaller boxes with cables, others are larger boxes without cables. I've only tried one with a small box that has input and output cables, which are connected as so:
PC > DAC > RCA > hum destroyer > amp > headphones
The one that I tried did technically reduce the hum (it completely removes the noise), however, it also affects the sound quality, specifically worse bass, and frankly overall it just sounds noticeably worse. It also has a lower dB (I have not measured it, but the volume knob is able to go significantly higher).
I also have an ifi Defender+ coming in the mail, which goes before the USB cable instead of between the RCA cables. Before I open that one, what is the likelihood that it will fix the issue without degrading sound quality?
And if all these devices cannot fix the issue without degrading sound quality, what the hell am I even doing?? I just want to listen to music without that terrible hum.
I plead to you all, please please please help me remove this terrible hum. It's destroying my life.
Thank you.
- Computer (CPU: 5700X3D, GPU: RTX 3090, the rest is pretty standard)
- Monitor (IPS-LCD)
- Monitor (OLED)
- TV (VA-LCD)
- Amp (XDUOO MT-602)
- Phone charger (65W)
- Pedestal fan
Thank you.
