The phono preamp is a Jolida JD9, here is a link to the manual:
https://www.manualslib.com/manual/1015268/Jolida-Jd-9.html#manual
It does mention that it must be connected via a 3prong plug to a "wall" receptacle or similar heavy-duty source, and to avoid extension cords (guilty on all charges initially but did just try the receptacle as well).
That's common for equipment with "vacuum bulbs" (as shango066 calls them). If in doubt, electrical safety > audio concerns. It still means it's an IEC Class I device, which as you have found can wreak all sorts of havoc with unbalanced audio connections if multiple of those are involved. I would prefer one that gets by with a modest transformer plug pack.
I do have to mention that my turntable is a VPI Player (hey, I had to save money somewhere)
Well, "save money" is all relative. That thing costs the better part of 2 grand if I'm not mistaken - some people don't spend that much on a car, and entire perfectly decent audio systems have been built for less. Manufacturing quality seems solid, but it's very barren on the feature side, the tonearm doesn't even have antiskating (
?! - I can only imagine what our
@restorer-john would have to say on that). Other manufacturers also seem to have figured out how to run tonearm wiring through the base decades ago. If you didn't actually need the headphone amp functionality or preamp, you could have bought a superb Technics (like the SL-1200GR) for that kind of money!
that has a built-in phone preamp section which I disabled (following VPI's youtube video). I read that someone had noise issues as doing so renders the ground screw useless (VPI's answer when he contacted them), so he somehow wired it where the ground screw could be used again. Maybe that's all I need to lower the noise from the phono preamp, I suppose those ground screws on turntables and next to the phono inputs on amps/preamps must be there for a reason
Here's the video, and the comment in question:
I did this to run it through a Shiit Mani and was getting pretty significant hum. After troubleshooting I narrowed it to something in the turntable. After I contacted VPI, I was told that the tonearm isn't grounded if you bypass the phone stage, but what it really seemed to be had to do with the power going to the board for the pre-amp. I thought about this because even with everything bypassed, turning the volume knob up made the noise worse. I disengaged the one harness labelled pre-amp and it's working great now with no noise.
I suspect the fact that the turntable is an IEC Class I device may have something to do with that. A turntable with no extra circuitry can just route the tonearm wiring through no matter what the motor drive circuitry is doing, but with a preamp installed things are a bit more complicated. Unplugging preamp power may be what's needed to resolve the ground loop. (Or maybe it's just capacitive coupling via the mains transformer?) Having a ground loop running over your phono audio cable obviously is about the worst thing possible, given how low signal levels are on there.
The extra ground connection in a standard turntable connects to the tonearm tube to provide electrostatic shielding for the wiring running inside. (If this is not working, the hum should react to your hand getting close and such.) The idea is to have separate grounds for left, right and shield that are only coming together at the preamp (star grounding), so as to avoid any internal ground loops. A bit of tracing with a multimeter may be needed to determine what is happening inside the VPI.
BTW, you'll probably want some pseudo-balanced cables
like these for your problematic AVR to amp connection. Well, actually, they may help out the phono preamp to amp connection as well. You spent enough money on an integrated amp with balanced inputs, so you might as well use them as intended.
