Curvature
- Joined
- May 20, 2022
- Messages
- 2,477
- Likes
- 3,962
Maybe start with one and see if you like it.For $25K I can get 5 X 8361
The robotic assembly vibrates. It is not clear to what extent that affects measurements, although I'm sure it introduces small resonances that affect FR. The way to check would be to look for correlated data across many speakers.I am also a bit reserved when it comes to NFS results under very specific circumstances posing severe problems even under true anechoic conditions (such as active cardioid cancellation, very very big diaphragms or sound sources out-of-phase being far away from each other so at 1m I would not expect anything like an even wavefront). Whenever the d.i. is abruptly below 0dB, I take a closer look.
That is not the case here. Everything looks consistent. Ripples might be a side effect of lots of narrow-banded EQ corrections being applied based on a measurement at a different position or with different smoothing.
I auditioned them and liked themMaybe start with one and see if you like it.
Doesn't count if you didn't buyI auditioned them and liked them![]()
If I had the money I'd buy themDoesn't count if you didn't buy![]()
It's one of the best speakers measured on ASR, ever, one of very few. It is also sent in by the company who know pricing is exotic. What other company with such exotic priced speakers dared to send them to ASR for measurement, none!!!! .I don't know why you & some others in this thread have a problem pointing out flaws in the speaker, it's not perfect, and it's an expensive product - the bass is it's weakness, it's not a perfect speaker, and you could say the response is quite sawtooth from 350Hz - 2000Hz if you're being picky. So it's expensive and has a flaw or two, so why have a problem that people point out it's deficiencies. It's totally normal and not out of order to express perceived issues.
why would you want 5 x 8361 when you can buy 50 x Neumann KH 120 for the same price?For $25K I can get 5 X 8361
I don't see any of these for sale on the used market.....so that speaks to your point.And the main echo in the reactions is focus on the perceived weaknesses, even if there are virtually no examples on ASR that measure better. And then the kind of conclusion becomes that it must be a mediocre speaker at best. I don't find that normal. What if you could buy a set for less than €8K 2nd hand, would that change things?
Thanks for your contributions to the forum. Your input interests me, objective measurements and your interpretation of what it sounds like, especially.I am also a bit reserved when it comes to NFS results under very specific circumstances posing severe problems even under true anechoic conditions (such as active cardioid cancellation, very very big diaphragms or sound sources out-of-phase being far away from each other so at 1m I would not expect anything like an even wavefront). Whenever the d.i. is abruptly below 0dB, I take a closer look.
They're too smallwhy would you want 5 x 8361 when you can buy 50 x Neumann KH 120 for the same price?
They weren’t an easy sell, customers by and large found the aesthetics ‘challenging’ and when the 8Cs were released well no comparison.I don't see any of these for sale on the used market.....so that speaks to your point.
I'm not sure how many LS1 speakers have been sold. But seemingly the buyers like them and they're doing the job in the field. You can't argue with objective data like that.![]()
pre ring for phase linear is only an issue if you limit the bandwidth (high or low pass). If you only make the xovers phase linear then you can end up with a minimum phase band pass, eg from 20-20k. This is also reflected in the step response (sharp coherent rise and then slowly relaxing back to zero). This has no pre ring but is not phase linear around the band edges but phase linear in between. The big question is if there is an advantage to also phase correcting the high pass (eg20Hz corner) and if the pre ring causes issues. interesting if someone has experience here.I assume you mean the original LS1 'whitepaper'. If so, given that one of the design requirements was to be as close to linear-phase as possible, then of course passive can not meet that requirement.
That said. and switching gears, the paper has always felt to me to be more of a marketing piece, than a technical paper.
i think while it makes very valid points about obvious FIR misuses, it also uses very overblown examples ('trainwrecks') to support their LS1 processing solution.
I question why present such overblown, bad-practice examples, other than for making splash.
Further, the technique in the paper of using an inverse-all pass via FIR to eliminate the phase rotation of a standard LR 24 crossover surely works.
But it is no different than using a linear-phase crossover to begin with, on top of the same IIR filtering needed either way for the drivers. A linear-phase crossover and reasonable driver corrections could of been used in "non-trainwreck" examples. (which would have made a much more valid basis for technical comparison to their electrical filter phase correction solution).
To the extent either one of these techniques doesn't have fully acoustic complementary response through crossover on and off-axis, they both have the same pre-ring potential.
No difference.
The paper makes it sound like the electrical filter linearization is superior, with no pre-ring potential ....(like is often feared with linear-phase crossovers lol.)
That's clever technical marketing, imo.
Pls don't get me wrong...I think the Grimm paper has some excellent and accurate info..
But the way the info is presented, seems to be about inflated techno-selling. Which seems to be central to the marketing and pricing strategy.
People want box speakers. Or speakers that look like box speakers. This is where the market is, unfortunately.They weren’t an easy sell, customers by and large found the aesthetics ‘challenging’ and when the 8Cs were released well no comparison.
I would like for my speakers to look like two bladesPeople want box speakers. Or speakers that look like box speakers. This is where the market is, unfortunately.
I don't really see it as one of the best speakers measured on ASR. The most impressive thing is the Horizontal Beam Width though. Now if it could do the bass better, then yes I'd say it's one of the best, but no. Yes, and overall you take the price into consideration, and would have voted it higher if it wasn't so expensive for instance.It's one of the best speakers measured on ASR, ever, one of very few. It is also sent in by the company who know pricing is exotic. What other company with such exotic priced speakers dared to send them to ASR for measurement, none!!!! .
I did this several times and when the corner frequency is low enough and the slope is shallow (2nd or 3rd order), it can work quite well, even though the improvement is not that audible.The big question is if there is an advantage to also phase correcting the high pass (eg20Hz corner) and if the pre ring causes issues. interesting if someone has experience here.
Personally, I think the most important thing to correct in a speaker setup is the sub-to-woofer XO (often a LR4 @80Hz) followed by the woofer-to-mid XO. When the main speaker is a two-way as in the case of the LS1 the benefit from having a linear-phase XO at several kHz is not that big.
I found a rock solid phase coherence between ways at higher XO's -- like a stable 0degree offset in case of LR-types -- is more important than whether the whole thing is linear phase or allpass phase. If it is not coherent, imaging tends to suffer. Linear phase is then the icing on the cake. But for low frequency XOs I find it mandatory.
