Not an inquiry, but did you also measure vertical towards up and a little bit to the sides, horizontally?
There's so much theoretical talk about this speaker, if it is beautiful, and how bass shy it is in all its excellence on paper.
But is such a wide dispersion really desirable? It realizes +/-100° (-6dB) roughly, while a KEF R series would do +/-50°. And if I read it right, the LS1 was ousted by the Kii, cardioid etc/, same developer?
It may also raise the question if the more discriminative test listening in mono is as easy as it sounds ;-) Such a wide speaker ;-) would feel better to the ears due to many reflections, less sharp, less empty in comparison to again a KEF R series.
Not the least, to put a speaker into a well filled ;-) bookshelf might have a similar effect as the wide baffle. But that is an antiquarian idea ;-) me thinks.
ps:
- may it be worthwhile to exchange the ceiling bounce with the floor bounce and vice versa; could be done via a software update
- the wiggles in the nearfield bass response in higher frequencies may originate in the residuals from the midrange speaker
- bass response, if meant to be anechoic, is perfect for room integration; distortion taken in percentage will drop by a factor of two or more in-room, and bass mangement will ask for extra subs distributed around the room anyway, as always, and then equalize to individual taste
I did not perform any off axis measurements of my DIY speaker. I did the typical measurements on axis including reversing the phase and adjusting the delay to get the best null for the crossover. With the 4th order LR crossover driver overlap is not going to be a big problem. With a flip of the switch in the DSP an 8th order LR could be substituted in.
Don't read too much into my measurements of my DIY mockup. A few months after I made these measurements I found that my 1982 JVC measurement mic response had developed some new bumps in the response and the calibration curve I created was flawed. Off axis measurements of my mockup would not represent the LS1 as my drivers were offset horizontally from center and the vertical spacing of drivers is larger due to cabinet walls in the way.
I found the bass of my DIY speaker to be very satisfying and just what you would expect from any quality 8" driver in a sealed box.
As I have been building very wide dispersion omni-directional spheres and very nearly omni-directional bipole speakers of late, so I thought of this LS1 as a relatively narrow dispersion speaker.
Bipole (drivers front and back) 20 drivers on sphere 6 drivers on sphere
The LS1 with 29 mm dome, with a waveguide, and an 8" woofer on a wide baffle will present as narrow dispersion relative to say an LS3/5a with a 19 mm tweeter, no waveguide, with a 4" woofer on a very narrow baffle. My narrow dispersion speakers are a pair of JBL 28P with the large waveguide.
It comes down to what you want. A very narrow controlled dispersion, cardioid pattern, in a padded control room adds nothing from the listening room to the playback content and presents a window into the performance space equivalent to opening up a big hole in the wall to a performance happening in the adjacent room with all of it's spatial information unmodified. This is perfect for mixing.
The opposite end of the presentation spectrum is the omni-directional speaker in a lively room ideally playing a performance with little or now ambient information so the presentation is that of the instruments playing at the speaker locations or on a line between them in the acoustic space presented by your listening room.
Most speakers are in between these extremes and most have wild swings in dispersion up and down the scale.
To sample the whole menu leads to accumulation of about ten pairs of speakers to cover the range as I have, or look at the variable dispersion speakers like the B&O Beolab 90, so you can switch modes, front firing, cardioid, omni-directional, with the remote control. I achieved the variable dispersion trick with my 20 driver spheres separating the drivers in the three groups and selecting different phase, delay and EQ with the DSP as the Beolab speaker does.
