Grace M101 Microphone Preamp Review
Rate this microphone preamp:
    Votes: 1 0.8%
    Votes: 0 0.0%
    Votes: 25 21.0%
    Votes: 93 78.2%
This is a review and detailed measurements of the Grace Design M101 single channel microphone preamp. It is on kind loan from a member and costs US $833.
OK, this is not a design that I would fall in love with but in the context of studio gear, it will get a pass.
I really like the gain setting knob. On the left, you set it in coarse steps but then can fine tune (positively) with the right knob. Works well.
Ribbon button per documentation gives you a DC path with no phantom power. HPF does what it says (see measurements below).
Back side is simple:
Grace M101 Professional Microphone Preamplifier review ribbon back panel high z.jpg
For testing, I used XLR out and input.
I have not done too many mic preamp measurements. I noticed company had very detailed specs so I decided to replicate them.
Grace Design M101 Microphone Preamp Measurements
Company spec standardizes on 20 dBu output at three different gain settings. I followed suit:
Across all three gain settings, actual results beat the company spec. Distortion is vanishingly low as well. Nice!
Company provides a single IMD spec but I decided to run a full sweep:
Grace M101 Professional Microphone Preamplifier 40 dB Gain IMD Measurement.png
Again, we beat company spec and this time, by fair bit. Nice again!
With respect to frequency response, I am seeing more attenuation in ultrasonic than company states:
Grace M101 Professional Microphone Preamplifier 40 dB Gain Frequency Response Measurement.png
It doesn't matter in practice but there it is.
I imagine the most important bit is Equivalent Input Noise (EIN). I set the amp to 60 dB gain and ran the "recorder" output averaged at three source impedances:
Grace M101 Professional Microphone Preamplifier 60 dB Gain EIN Measurement.png
I more or less grabbed the peak value. Using those, we see that we essentially match company spec.
I don't think I have seen this level of honesty and excellent performance from a company. The M101 delivers same or better performance in all of their specs. Price is up there but as is attention to circuit design hygiene.
I am happy to recommend the Grace Design M101 microphone preamp.
This device is nowhere near my current wheelhouse although I’m proud to say I did have some mixing board experience on my high school AV crew.
With that in mind, this seems to be very expensive for what it does.
Thanks for the review and member who sent it in.
Looks great, although for a single channel it might be considered somewhat pricey. I personally know at least one studio that has this pre in regular use.
Interestingly It’s far from a new design, it was released in 2008 and is a development of the Model 101 released in 2001.
The inclusion of the ‘Ribbon mode” is interesting. They state it bypasses the input decoupling capacitors and raises the input impedance from 8.1kΩ to 20kΩ.
Maximum of 75dB of gain when the trim pot is at +10 is a healthy amount.
This is their August 2008 newsletter that they still have available online with the release info if anyone is interested. https://www.gracedesign.com/newsletter/august08/newsletter08_08.htm
The company is clearly prepared to stand behind their product, the 20 year warranty is impressive!
Finally, additional context would be helpful to judge where it sits in the clean mic pre market, I can only find tests of interfaces such as the Focusrite Scarlett and the ADC has generally been tested with a much stronger signal than you might get with a microphone, have any comparable microphone preamps been reviewed on ASR?
Measurements aside (really good), what I do know about Grace designs is that they work, no matter what, to the point it becomes boring after some decades (no drama, for good or bad for a tinkerer :p )
Thanks Amir!
I wonder what the use case of such a device would be in today's market
Was asking myself the same question. In any setup, be it a large recording studio, small home studio or mobile recording, you'll be using an audio interface (unless you're *really* mobile and use a fully integrated recorder) with integrated mic preamps.
And if you have the money to buy a near 1K standalone single channel mic pre, you can also buy a top of the line audio interface and have no need for an external, non remote controlled single channel mic pre. Would be interesting to see how a top tier audio interface mic pre compares against this one in terms of noise floor. The 300 Ohm output impedance is a lil rough tho. That won't pair too well with the Cosmos ADC, which would otherwise be the obvious choice to digitize whats coming out of a high SNR mic pre.
A lot of project studios want 1 or 2 'drive anything' mic pres to augment what is built into interfaces / consoles. I have owned one of these for 20+ years.
A new brand for me! Considering the praise so far and the test results from @amirm, I’ll definitely check them out.
Thanks!
Great data and seems to be a sound design. Price is for Pro usage, in Germany relatively expensive. What I would like to see is a display of the db adjustment setting and a lower output impedance in the region of 50 Ohm. But I do not record. So the Pro's need to check the unit for specific microphones and A/D units.
I own the previous version of this that doesn’t have the ribbon mic option. It’s a startlingly clean preamp.
The use case is pretty simple: you want a distortion-free gain path to your ADC with no compromises. We’re talking about recording individual vocals & acoustic instruments using a variety of microphones.
Here’s where this fits:
• Audio interfaces that have one or two mic preamps are usually “prosumer” grade: fine for podcasts & simple demos, but not good enough for studio grade recording
• Audio interfaces that are professional grade have too many mic preamps. Personally, I have no need for 8 mic preamps. I do, though, need one really, really good one. Haven’t seen any bench tests of $2-4k interfaces (their specs look great), but there has to be some place where they lack just a hair in performance with 8 or more mic inputs.
• In both cases, you have long cable runs from the microphone to the mic preamp/ADC since the interface is close to the computer. Again, running under the assumption you’re attempting serious recording, not a podcast in your garage.
The cable runs between transducers and their electronics should be as short as possible. Since microphones and loudspeakers are both transducers, it applies equally. Once you’ve gotten the reactive, low-level mic signal turned into a high-output line signal, go ahead, have your 30ft cable run to the ADC.
I use a Mogami Platinum Studio 3m cable from mic to pre. It’s the beefiest mic cable I’ve ever seen (18 gauge wire - $100).
It wasn’t tested, but the high impedance input is fantastic for electric guitars. I astonished a friend when I brought his Parker Fly straight in through pre/ADC and ran that clean signal through 3 different virtual amps (Marshall, Soldano half stacks and a Fender Twin) cranked in 3 different virtual rooms with a ton of effects. His mind was BLOWED! Permanently.
Another small consideration is that, psychologically, the artist feels part of the engineering process when they have the mic preamp and ADC with its meters right in front of them. I have mine in a rack case on a guitar amp stand angled upward toward them.
