GR Research Speaker Upgrade Review (Sierra-2EX V2)
Rate this speaker "upgrade:"
    Votes: 359 96.2%
    Votes: 7 1.9%
    Votes: 3 0.8%
    Votes: 4 1.1%
In the important 1-8 kHz range the AsciLab F6B is so much cleaner than both Versions of the Ascend Sierrra.
Even at 91 dB!!!
Even at 96 dB!!!
This is a detailed review and measurements of a speaker modified by GR Research and compared to factory performance. The modification kit costs US $510 that you have to assemble:
I know, not much to look at. :) But the left one was upgraded by the Ascend founder/designer Dave to include Danny's modified crossover. As noted, you get a bag of parts and it is your responsibility to figure out how to a) assemble them and b) how to stuff them in the cabinet. Dave reported that this was very difficult due to size of the GRR crossover size/parts. To get it done, he used an older port tube and hence, there is tiny bit of difference in bass response between the two. Otherwise, the two are the same.
I measured both speakers using Klippel Near-field scanner with 1000 frequency response measurements in 3-D space to compute anechoic radiation of the speaker. Accuracy was high, keeping error to below 1%. Before I show you that, let's look at the measurements as provided by GR Research. Note that he made two mods. The version I have is I guess can be called "V1." After he heard objections from Dave, Danny redid the mod and provided the following measurements:
My first objection is what on earth he thought was wrong with the stock crossover on the left. Those few wiggles are enlarged due to improper vertical scale (should be 50 dB vs 25 dB). The best fix for that is electronic EQ, not the coarse set of filters in crossover. Regardless, looking on the right, I don't see any net improvement. We now have a broader dip from 1 to 2 kHz than we did before. Treble response above is flattened a bit but again, what was there didn't need fixing when we are talking about speakers.
But let's note how the measurements were performed. We see a start frequency of 200 Hz. This indicates measurements were performed in a room rather than anechoic chamber or free field. To get rid of inevitable reflections in the room, measurements were stopped after a few milliseconds ("gated measurements.") That avoids the reflective wave coming back. The price to pay is much reduced resolution well into hundreds of Hz.
On top of above, the graph is smoothed to 1/3 octave. Standards call for 1/20th of Octave as to not hide resonances. Many sins are hidden with such techniques. If the crossover response had huge error, then fixing that using these techniques kind of works. But here, we already have a high accuracy speaker. Attempting to correct its response using such blunt measurements is a mistake. Let's see that in practice with our high resolution scans.
EDIT: here is a capture of before and after for Danny's original version of the mod:
Again, I don't see how a case can be made that anything is improved.
GR Research Speaker/Crossover Upgrade Measurement & Review
Let's get our baseline response by measuring the Sierra-2EX V2 with stock factory crossover:
The graph is a bit rougher than company publications due to me using higher resolution (20 points/octave vs 12). We see some small resonances but otherwise, response is more or less flat on axis. Directivity is very good as we will see later. While sound power is not predictive of performance, it too looks very good (red, bottom).
Notice the lack of correlation with Danny's measurements. There is no dip from 1 to 2 kHz. But rather a resonant peak.
Now let's look at Danny's modified crossover measurements:
As you see, the on axis response is fair bit degraded. We now have a valley from 2 to nearly 5 kHz. And some boosting of highs above 11 kHz. Comparing the two without the other graphs we get a better picture:
I don't see any improvement one could hang his head on. The reduced energy from 2 to 5 kHz is likely to impact the soundstage in a negative way. And boosted upper trouble, bothersome to younger listeners.
Danny speaks a lot about correcting off-axis response:
The sum total of loudest reflections with factory crossover is almost perfect. Clearly work has been done to optimize this. Seeing how Ascend has a Klippel NFS, it is no wonder that Dave has gone there.
In comparison, the modified crossover by Danny, has shattered that beauty with that sudden rise in treble. Now, depending on how much absorption you have in your room, the overall tonality will differ, requiring more messing around with the room.
Question is why Danny thought the upper treble needed boosting at all. I wonder if he did not aim his measurement mic directly at the tweeter. Or worse yet, he has a microphone with compromised response. If so, that means the rest of his measurements may be in error as well.
No surprise that predicted in-room response is thus:
I recall Dave complaining about the modification ruining the in-room response and overall directivity and we have clear evidence of that here.
Another major objection from Ascend was that the modified crossover, which pulls the crossover point lower, risks damaging the RAAL tweeter. If we look at the stock distortion tests, we see that there is already elevated distortion (left):
In exchange for that, wider directivity is provided as compared to dome tweeter. So perhaps the trade off is worth it. But not when we look the modified crossover, where tweeter distortion is doubled, showing clear stress starting around crossover frequency.
We can focus on near-field of the tweeter to confirm the same:
There is no question that poor judgement was used to make this change, especially since we see no benefit elsewhere.
Another change GR Research made was to flatten the impedance at higher frequencies. Case was made that tube amps with their high output impedance, like to see flatter impedance. This is true but that is a flaw in tube amps, not a reason to cater a speaker to them. After all, only a small percentage of people will use a tube amp with this speaker. Even for those people, it is unpredictable what the frequency response change will be, preference wise. Here is the comparison anyway:
We see that the minimum impedance has dropped from a good 5 ohm, to low 3.8 ohm. If GR Research is worried about amplifiers, this would be a reason enough not to make the changes they have made.
I have not listened to either speaker. GR Research made all of their modifications based on measurements and no listening tests at all. So I am doing the same.
The answer here is clear: the Ascend Sierra-2EX V2 is already optimized design with stated of the art measurement system and talented designer. Danny from GR Research should have realized this and passed on doing any "upgrades." Failing to recognize that, he used very rough, inaccurate measurements to make changes to the crossover. The result was an expensive set of parts which under any objective evaluation from tonality to distortion and reliability, degrades performance.
That is on top of sending a bunch of oversized parts to some poor owner, making them responsible to figure out how to get them to fit. Danny has not shown how to do this so one wonders if he has built said crossover and managed to stuff it in the speaker.
In my opinion, this is a clear downgrade rather than any kind of "upgrade." Company should stay in its lane and go after designs with clear and large deficiencies in crossover which can be seen with his rough measurements. Even there, I don't think it makes sense to spend this kind of money and time to fix a speaker and ruin its resale and warranty. Sell them and get a proper speaker, preferrably one that has benefited from proper design and instrumentation.
Needless to say, I can't recommend GR Research Ascend Sierra-2EX V2 speaker kit.
@Maiky76: there is some work to do ;) !
Would be nice to have the spinorama numbers of both versions……
Sierra-2EX II was already measured with the Klippel. But only by the factory itself.
Erin has found out that the Sierra-LX (with conventional tweeter) was quite significant lower performing in Erins measurements than in Ascend Acoustics Klippel-measurements!
Here we are speaking of the EX Version.
@amirm ´s measurements seem to be pretty close to factory measurements!
So, I believe that the Sierra 2EX, in its unmodified version, belongs to the top 5% of speakers you can buy for under, say, USD 3000 per pair.
I don't understand your point. The vote allows voting. Anybody is free to vote for what he wants.
I agree. It’s just a vote, it is not a meaningful data point, just an interactive element of the review threads.
I voted good once for a generally considered non performing product, just because I like it and it brings back good memories. I know it objectively does nothing much.
Yes, the fact that it is worse than the original and USD 510 more expensive, and that you have to do the soldering by your own doesn’t makes it a bad speaker at all. Objectively the downgrade is not by a huge margin and the quality all in all seems to be decent. So I have not voted.
I also think that Danny makes some bad stuff and also some quite good stuff!
Because of his power cable voodoo he is not liked by this community.
But some of his modifications (and some of his originals) are very nice speakers.
When I saw his rope cables (seriously Danny?), I wished him a healthy dose of Ropeburn.
A little reading on the websites is enough to realize that GR Research has an approach worthy of a used car salesman...
First, what surprises me is that Danny never talks about his methodology for audio measurements.
A website that doesn't present its methodology, measurement tools, etc., is absolutely not credible, at least in my opinion...
Here is the measuring device used by GR Research for those who haven't yet asked themselves the question:
Audiomatica
Danny uses measurements only when it suits him, This is often the problem for people who consistently fall into confirmation bias...
If you think about it, the SIERRA-2EX speakers have already undergone Klippel NFS testing. Who would be foolish enough to perform an "upgrade" based on Audiomatica tests?
It makes no sense, since Klippel tests are the gold standard. In fact, GR Research is offering "downgrades," and that's a revolution for naive audiophiles.
A small addition to Amir's review that's worth reading about GR Research :
He doesnt think klippel is any good, you can ask him about it.
Of course they are - we are trying to understand though why people are voting positively for an obviously broken product. There are only a small number of possible explanations.
I know someone else with little time for the Klippel test suite. I'll stick me neck out again and suggest it's jealousy!
Someone should contact all the speaker companies he has mods for, and ask if they're ok with Danny using the companies copyrighted photos for his own profit. I know Ascend was not pleased and Danny had to change the image. He said he "wasn't sure if it violated copyright or not". Hell I'll do it I'm bored.
Sent emails with images to KEF, ATC, Focal, B&W, JBL, Wharfale, and a few more. The trick here is that if Danny doesn't still have the speaker he modded, he can't take his own photos of it. He will have to get permission from someone else to use their images. No company will give him permission to use the images. Shall see how this plays out.
That's what scam artists do. Feel sorry for the dummies that fall for such charlatans.
And he's selling "mods" for 44 fine, well designed speakers, hah! https://gr-research.com/speaker-upgrades/
Who would spend $300 to upgrade a $90 Sony speaker?
I'm loss. Of course anyone can do anything they want with their money. . . but that also means, I can laugh at any one of these fools.
