GR Research Speaker Upgrade Review (Sierra-2EX V2)
Rate this speaker "upgrade:"
    Votes: 359 96.2%
    Votes: 7 1.9%
    Votes: 3 0.8%
    Votes: 4 1.1%
This is a detailed review and measurements of a speaker modified by GR Research and compared to factory performance. The modification kit costs US $510 that you have to assemble:
I know, not much to look at. :) But the left one was upgraded by the Ascend founder/designer Dave to include Danny's modified crossover. As noted, you get a bag of parts and it is your responsibility to figure out how to a) assemble them and b) how to stuff them in the cabinet. Dave reported that this was very difficult due to size of the GRR crossover size/parts. To get it done, he used an older port tube and hence, there is tiny bit of difference in bass response between the two. Otherwise, the two are the same.
I measured both speakers using Klippel Near-field scanner with 1000 frequency response measurements in 3-D space to compute anechoic radiation of the speaker. Accuracy was high, keeping error to below 1%. Before I show you that, let's look at the measurements as provided by GR Research. Note that he made two mods. The version I have is I guess can be called "V1." After he heard objections from Dave, Danny redid the mod and provided the following measurements:
Ascend Sierra 2EX V2 GR Research Danny Speaker crossover mod upgrade company kit measurements.png
My first objection is what on earth he thought was wrong with the stock crossover on the left. Those few wiggles are enlarged due to improper vertical scale (should be 50 dB vs 25 dB). The best fix for that is electronic EQ, not the coarse set of filters in crossover. Regardless, looking on the right, I don't see any net improvement. We now have a broader dip from 1 to 2 kHz than we did before. Treble response above is flattened a bit but again, what was there didn't need fixing when we are talking about speakers.
But let's note how the measurements were performed. We see a start frequency of 200 Hz. This indicates measurements were performed in a room rather than anechoic chamber or free field. To get rid of inevitable reflections in the room, measurements were stopped after a few milliseconds ("gated measurements.") That avoids the reflective wave coming back. The price to pay is much reduced resolution well into hundreds of Hz.
On top of above, the graph is smoothed to 1/3 octave. Standards call for 1/20th of Octave as to not hide resonances. Many sins are hidden with such techniques. If the crossover response had huge error, then fixing that using these techniques kind of works. But here, we already have a high accuracy speaker. Attempting to correct its response using such blunt measurements is a mistake. Let's see that in practice with our high resolution scans.
EDIT: here is a capture of before and after for Danny's original version of the mod:
Again, I don't see how a case can be made that anything is improved.
GR Research Speaker/Crossover Upgrade Measurement & Review
Let's get our baseline response by measuring the Sierra-2EX V2 with stock factory crossover:
The graph is a bit rougher than company publications due to me using higher resolution (20 points/octave vs 12). We see some small resonances but otherwise, response is more or less flat on axis. Directivity is very good as we will see later. While sound power is not predictive of performance, it too looks very good (red, bottom).
Notice the lack of correlation with Danny's measurements. There is no dip from 1 to 2 kHz. But rather a resonant peak.
Now let's look at Danny's modified crossover measurements:
Ascend Sierra 2EX V2 GR Research Danny Speaker crossover mod upgrade Anechoic CEA2034 Frequenc...png
As you see, the on axis response is fair bit degraded. We now have a valley from 2 to nearly 5 kHz. And some boosting of highs above 11 kHz. Comparing the two without the other graphs we get a better picture:
Ascend Sierra 2EX V2 GR Research Danny Speaker crossover mod upgrade comparison Anechoic CEA20...png
I don't see any improvement one could hang his head on. The reduced energy from 2 to 5 kHz is likely to impact the soundstage in a negative way. And boosted upper trouble, bothersome to younger listeners.
Danny speaks a lot about correcting off-axis response:
Ascend Sierra 2EX V2 GR Research Danny Speaker crossover mod upgrade Early Room Reflection Fre...png
The sum total of loudest reflections with factory crossover is almost perfect. Clearly work has been done to optimize this. Seeing how Ascend has a Klippel NFS, it is no wonder that Dave has gone there.
In comparison, the modified crossover by Danny, has shattered that beauty with that sudden rise in treble. Now, depending on how much absorption you have in your room, the overall tonality will differ, requiring more messing around with the room.
Question is why Danny thought the upper treble needed boosting at all. I wonder if he did not aim his measurement mic directly at the tweeter. Or worse yet, he has a microphone with compromised response. If so, that means the rest of his measurements may be in error as well.
No surprise that predicted in-room response is thus:
Ascend Sierra 2EX V2 GR Research Danny Speaker crossover mod upgrade predicted in-Room Frequen...png
I recall Dave complaining about the modification ruining the in-room response and overall directivity and we have clear evidence of that here.
Another major objection from Ascend was that the modified crossover, which pulls the crossover point lower, risks damaging the RAAL tweeter. If we look at the stock distortion tests, we see that there is already elevated distortion (left):
Ascend Sierra 2EX V2 GR Research Danny Speaker crossover mod upgrade distortion comparison.png
In exchange for that, wider directivity is provided as compared to dome tweeter. So perhaps the trade off is worth it. But not when we look the modified crossover, where tweeter distortion is doubled, showing clear stress starting around crossover frequency.
We can focus on near-field of the tweeter to confirm the same:
Ascend Sierra 2EX V2 GR Research Danny Speaker crossover mod upgrade tweeter distortion compar...png
There is no question that poor judgement was used to make this change, especially since we see no benefit elsewhere.
Another change GR Research made was to flatten the impedance at higher frequencies. Case was made that tube amps with their high output impedance, like to see flatter impedance. This is true but that is a flaw in tube amps, not a reason to cater a speaker to them. After all, only a small percentage of people will use a tube amp with this speaker. Even for those people, it is unpredictable what the frequency response change will be, preference wise. Here is the comparison anyway:
Ascend Sierra 2EX V2 GR Research Danny Speaker crossover mod upgrade impedance and phase compa...png
We see that the minimum impedance has dropped from a good 5 ohm, to low 3.8 ohm. If GR Research is worried about amplifiers, this would be a reason enough not to make the changes they have made.
I have not listened to either speaker. GR Research made all of their modifications based on measurements and no listening tests at all. So I am doing the same.
The answer here is clear: the Ascend Sierra-2EX V2 is already optimized design with stated of the art measurement system and talented designer. Danny from GR Research should have realized this and passed on doing any "upgrades." Failing to recognize that, he used very rough, inaccurate measurements to make changes to the crossover. The result was an expensive set of parts which under any objective evaluation from tonality to distortion and reliability, degrades performance.
That is on top of sending a bunch of oversized parts to some poor owner, making them responsible to figure out how to get them to fit. Danny has not shown how to do this so one wonders if he has built said crossover and managed to stuff it in the speaker.
In my opinion, this is a clear downgrade rather than any kind of "upgrade." Company should stay in its lane and go after designs with clear and large deficiencies in crossover which can be seen with his rough measurements. Even there, I don't think it makes sense to spend this kind of money and time to fix a speaker and ruin its resale and warranty. Sell them and get a proper speaker, preferrably one that has benefited from proper design and instrumentation.
Needless to say, I can't recommend GR Research Ascend Sierra-2EX V2 speaker kit.
I saw this coming a mile off. Raal themselves said that crossing the tweeter this low is a really bad idea.
And, unsurprising that it's worse.
Ah, the saga continues. I actually asked Danny about the distortion issue awhile back and he said you can't measure distortion so there's that. For a guy who builds his whole business around being better than the "big scary speaker companies", he seems to deliver some pretty poor work. This mod should have really killed his entire crossover mod business, because it shatters the illusion that he knows better. The fact that he later changed the mod to address the distortion (that you can't measure apparently) is further admittance that he doesn't live up to his own hype. The new mod circuit, if we go by Danny's data, is basically $450 for a different variation on the same filter tasks. It really presents no value to the customer what so ever.
It really says something when a driver manufacturer has to issue a statement to avoid this mod or else you'll risk damaging the driver. Has that ever happened before?
No, they loathe taking sides like this.
BTW, these are the published measurements on Ascend's website:
I have to think he did not bother to even look at them. As otherwise, anyone would conclude that there was nothing there to fix.
I want to know who voted "not terrible".
How can something that adds so much cost (and labor) to an already great speaker, that actually degrades the speakers performance, be given any other vote than "poor"?
@amirm , I'd love for the polls here to show who voted and how they voted. Any chance of changing polls so they do? I'm guessing no since it would allow members to be ridiculed by their vote.:)
Danny strikes again! Giving that speaker to Danny to improve is like giving an Olympic marathoner to a quack doctor to "improve" by implanting them with a baboon heart. Danny isn't just stupid, he's dangerous. When someone buys a speaker, like, for example, a Kef LS 50 meta, the value does not reside primarily in its bill of materials, but rather in the use its maker, its designer, made of those materials. Start swapping out parts, and you no longer have a Kef Ls 50 Meta, but rather some obscure design from some nobody. Better to keep Dr Jack Oclee Brown's design, it's legendary for a reason, and someone like Danny can never approach anything he, or Dave Fabricant, or the folks as Asci are doing, or he would be going great guns with his own world renowned speaker company. And he isn't.
As always, Amir, great job of pointing this nonsense out. Danny is the worst--he persuades naive hobbyists to ruin their perfectly good speakers by letting him "improve" them. And he's so ignorant, he's unaware that he knows very little about speaker design. There's a name for people with his kind of ignorance: It's called Dunning-Kruger syndrome, and it's the exact opposite of Socratic ignorance where an individual humbly recognizes their limitations and work hard to remove them. Putting someone with Dunning-Kruger in charge of anything is a recipe for disaster. True whether they're your dog walker, your nation's president, or just a guy claiming he can better the sound of your speaker for a few hundred dollars more. Whenever someone like that makes their presence known, best to run the other way.
If you feel like it Amir, this would be a good candidate for a video. Just to pour oil into the fire and see. Hehe.
Apart from the obvious botching and ridiculous prices, I can only repeat it's absolutely laughable you don't even get boards with the kit. Hundreds of dollars, specific speaker models, there's no excuse. Cheap educational kits for 10 moneys come with boards. Not simple circuits like a crossover with a handful of parts either. :facepalm:
Wow, but tell us what you really think!
I think this graph expresses a good bit of "meant well" while showing the crossover redesign was based on incomplete, erroneous low-resolution data.
The region above 2KHz looks smoother after the mod and it seems to me like only the woofer response was changed, which is why the difference in distortion is baffling to me, but I didn't have time to read the full post so I might be missing something here.
I think Amir meant "Smoothed" instead of "Gated" in that comment about resolution, because "Gated measurement" in itself does not mean low resolution and in fact is also how the HF Klippel data is obtained on a faster run.
What tanks resolution here is a combination of the extremely short (4ms) gating time (very poor LF resolution) and the 1/3 octave smoothing, which is ofc independent of frequency and completely demolishes any possibility to have any usable data. The speaker designer should have 1/24th data or better while 1/12th is a very usable resolution for speaker evaluation from a customer perspective.
