Such statements of Danny also bother me most because of its disinformation. So also added a comment to his Youtube video about this:He says he is using a 4mS gated window, which is equivalent to a 250Hz frequency resolution, and which is why he can't display any information below 200Hz !! What his software is probably doing is zero-stuffing the time response to 100 mS to get 10 Hz plot resolution, but there is still no more detail than with the original 4 mS window. It just smooths out the frequency response plot rather than leaving jagged lines connecting the points at each 250Hz interval, which is akin to oversampling in the frequency domain. Anyone who has studied FFT's will know this. This is why striving for high tap-count convolution filters in the reproduction chain is pointless if the sampling interval is limited and does not match. Hate to rain on his parade but Amir was not lying !!
Lookily due to AI many people have started verifying claims on their own, which often gives surprisingly good results.
What Danny is trying to do is convince you that measurements are irrelevant. Unless done by him...Danny responds to Amir. And does a pretty good job explaining what he does and poking some holes in Amir’s argument. Danny also pulled receipts of Amir and his website supporting Danny’s perspective of what impedance swings, mismatches and out of phase or current leading and lagging voltage and its affects on SQ. I watched both videos because I want to see the arguments of each and make my own opinions on how they frame their perspectives. They both make great points that are educational. I don’t care about either guy. I don’t have a dog in this fight. I like opposing viewpoints because I will never blindly follow any person.
Let's do another one then, based on Danies claim "I did have a full-size anechoic chamber when GR reserach first started. ...was like 23 feet Long.... we could take accurate measurements down to about 40Hz or so" (using foam wedges as he explains later in the video):
I spent many months researching chambers when we had our main facility in Gardena, CA (~2+ decades ago) We had the space but the cost was astronomical, with the lowest quote for a chamber tuned to ~100Hz being around $300K.
I have personally been in Harman's anechoic chamber, I can say for certainty that GR never had anything like it. Remember though, he also claims the CLIO is the same as Klippel NFS.I remember well when Danny used to claim he had an anechoic chamber. This was a long time ago, perhaps back in the early 2000's.
Not long after our CBM-170's were measured in the anechoic chamber at Canada's NRC, I had a disagreement with Danny's old boss, Mark Schifter, about the "anechoic chamber" claim. I told him it was more of a treated room than an actual chamber. It was far too small and did not have the requisite suspended mesh flooring over thick fiberglass wedges to absorb floor bounce.
Danny's "wedges" were only about 4 inches deep, maybe 6" at most and were open cell acoustic foam. At such limited thickness and the wrong material, it would, at most be "anechoic" down to, at best 500-600Hz - assuming the floor was covered in wedges and the walls were thick concrete.
His claim of anechoic to 40Hz is absurd, he either truly doesn't understand or is just outright lying. To be anechoic to 40Hz would require specialized fiberglass wedges (not acoustic foam) that would need to be at least 4 FEET in depth. I believe there are only a few chambers in the world that are anechoic to this low of a frequency. Even the widely used chamber at the NRC is generally only good down to ~ 80Hz.
Here is a pic of GR's so called anechoic chamber from their website back then...
I spent many months researching chambers when we had our main facility in Gardena, CA (~2+ decades ago) We had the space but the cost was astronomical, with the lowest quote for a chamber tuned to ~100Hz being around $300K. I did considered it, but child # 2 was soon on the way and as such, decided to stick with ground plane and nearfield techniques. We had a large flat parking lot which made taking ground plane measurements simple when everyone in the business park would go home. Many late nights back then, good memories for me.
It's telling when someone attempts to DIY such a chamber and doesn't ask himself why lots of established manufacturers use ground plane and nearfield measurements instead. But then Danny tells it like 'been there, done that'...
So his measurement error is a combination of both. There are bumps that pop out from the gating pretty bad. I'm not sure what the point of gating that hard is other than "I don't want to bother with ground planes or going outside"...I thought maybe it is interesting to actually visualize the effects of time gating and smoothing. I imported Erin's JBL L100 Classic MKII on axis measurement into REW, used "Generate minimum phase..." to generate an impulse response and applyed various levels of gating and smoothing up to the degree Danny does:
Thanks to link in my post here, I accidently used the "wrong" thread (too much Danny currently in this forumSo his measurement error is a combination of both. There are bumps that pop out from the gating pretty bad. I'm not sure what the point of gating that hard is other than "I don't want to bother with ground planes or going outside"...
What the hell??? Correct me if I am wrong but aren't alligator clips very thin steel that is plated? I don't think they are brass or copper.......am I wrong? If I am right than it blows his tube connectors and other cheesy parts mantra out of the water.This man alligator clips like a champion![]()
Well freely spoken, it matters fuck all. Danny knows it. Which is indeed illustrating nicely how cognitively dissonant or straight up lying he is. I suspect it's something in the middle, as always.What the hell??? Correct me if I am wrong but aren't alligator clips very thin steel that is plated? I don't think they are brass or copper.......am I wrong? If I am right than it blows his tube connectors and other cheesy parts mantra out of the water.
I'm not watching Danny's videos and assume he has crappy alligator clips...but to your general question, you can get nice copper alligator clips and use your own 12 gauge OFC cable. Some crappy/cheap alligator clips have a LOT of resistance.What the hell??? Correct me if I am wrong but aren't alligator clips very thin steel that is plated? I don't think they are brass or copper.......am I wrong?...
I’m pretty sure which it is.I just have also seen Danny's JBL L100 video and also stumbeled about his "Klippel averaging story" while refering to On Axis and Listining Window graph of Erin's Klippel measurment. He simply doesn't seem to understand that the On Axis response measured by the Klippel NFS is not averaged in any way and is in fact a extremly accurate high resolution measurement, which you otherwise can at best get from an ungated outdoor or anechoic chamber measurement and that instead it is his own time gated and 1/3 smoothed measurement which is degraded and low resolution. I am not sure if Danny didn't understand this or is intentionally trying to compromise the Klippel measurements.
I have as well, and I am fairly certain the skill, time and materials just to construct the suspended floor with 4' deep fiberglass wedges below is out if his scope.I have personally been in Harman's anechoic chamber, I can say for certainty that GR never had anything like it. Remember though, he also claims the CLIO is the same as Klippel NFS.
