I have been doing some research and I can confirm that ChatGPT is not useable, anymore. I say anymore as I have saved chats where it gave me correct results. When I use the exact same queries I now get wrong results. This was not the case, at all. Whatever they have done, there is certainly a change in the way ChatGPT works for me.
I have now tried Google Bart. The result is promising as Bart is now doing what seems to be proper calculations using external software. See the following example.
Q: Calculate a closed speaker box's volume to have a Q of 0.71, using a driver with the following parameters: Fs: 20Hz, Vas: 113l, Qes: 0.31, Qms: 5.1
A: Sure, I can help you with that.
The following Python code can be used to calculate the volume of a closed speaker box with a Q of 0.71, using a driver with the following parameters: Fs: 20Hz, Vas: 113l, Qes: 0.31, Qms: 5.1:
Code:
Python
import math
def calculate_volume(fs, vas, qes, qms):
q = 0.71
volume = (vas * q * q * q) / (qes * qms)
return volume
volume = calculate_volume(20, 113, 0.31, 5.1)
print(volume)
Use code with caution. Learn more
content_copy
This code will print the following output:
Code snippet
25.58124161922833
content_copy
This means that the volume of the closed speaker box needs to be 25.58 liters in order to have a Q of 0.71.
Here is an explanation of the code:
- The calculate_volume() function takes four parameters: Fs, Vas, Qes, and Qms.
- The Fs parameter is the speaker's resonant frequency.
- The Vas parameter is the speaker's compliance volume.
- The Qes parameter is the speaker's electrical Q.
- The Qms parameter is the speaker's mechanical Q.
- The volume variable is calculated as the product of Vas, q, q, and q, divided by Qes and Qms.
- The print() function prints the value of the volume variable.
I hope this helps! Let me know if you have any other questions.
Q: what will be the fb?
A: The fb, or cutoff frequency, of the closed speaker box will be about 35 Hz. This is calculated using the following formula:
fb = Fs * (sqrt(Qms / Qes) - 1)
Plugging in the values from the previous example, we get:
fb = 20 * (sqrt(5.1 / 0.31) - 1) = 34.93 Hz
So, the closed speaker box will have a cutoff frequency of about 35 Hz. This means that the speaker will produce full-range sound down to about 35 Hz.
Here is a table of the calculated values:
| Parameter | Value |
| Fs | 20 Hz |
| Vas | 113 l |
| Qes | 0.31 |
| Qms | 5.1 |
| Q | 0.71 |
| Volume | 25.58 l |
| fb | 34.93 Hz |
