GPT4 / CHATGPT Plugins for Speaker measurement analysis and comparison
For 20 bucks a month you can get GPT-4 with plugins to extract data from websites (and tons of other computations). GPT-4 is a lot better that ChatGPT and GPT 3.5. I'd wager that any info you get from it will be way more accurate than the typical post in these forums'
Yes I have been using the web-browsing plugin and it's pretty good at pulling content from specific webpages and summarising it and providing a nice "text" based response.
Also, the spinorama plugin is also in early alpha version thanks to @pierre but I think for proper and nerdy manipulation of real audio data the 'code interpreter' plugin will be needed - this plugin will be (or should be) amazing - in that its not that the ChatGPT that has to understand raw audio data, its that the person using this plugin give instructions in English to the plugin to generate 'data science' code which interacts / aggregates / filters etc the data that it has loaded. So you are not asking for a result directly from chatGPT, you are asking it to generate code using 'common' data science tooling, e.g. DataTables and pyplot which will give you the result you require - so much less likely to get 'hallucinations'
Still waiting for my access as soon as I do get it I will see can I do a few good examples and post them here or maybe in a new topic on ASR as examples.
Not sure if people have seen the latest announcement from openai which is that you can provide plugins directly into the GPT4 which can basically allow the AI to analyse raw datasets and allow easy "interactions" with the RAW data, providing visualisations etc. Specifically If people are interested there is a small section inside the "interpreter" plugin video near the bottom on this page https://openai.com/blog/chatgpt-plugins where they show pretty nice analysis music data, this IMO looks like the classic data science tool Juypter Notebooks plugged into ChatGPT.
So one idea I had looking at this was that maybe we can get the raw data from the various spinorama measurements plugged in and allow people to play around with comparisons between speakers in new and potentially useful ways. The big advantage of this is that it cuts out the big complaint about "ChatGPT" which is it can be just "making stuff up". So what do you think @pierre or @amirm ? I signed up for developer access so would be interested in assisting when I get access.
Note: Its obviously not just speaker measurements where this might be useful any raw audio dataset e.g. like headphone measurements would benefit from this so would be interesting if say @crinacle would also be interested.
Precisely why I am interested in GPT.
GPT-4 hallucinates facts and makes reasoning errors the same way ChatGPT does and should absolutely never be used for any kind of scientific work, like the kind of data analysis you're talking about. It is good at a lot of things. Giving it data and asking it questions about the data you need accurate answers to is not one of those things.
Yeah, it is the end of science, even the civilisation :facepalm:
This is nearly completely wrong! GPT-4 is far less likely to hallucinate
I have found that it is the best research tool availble, right up there with Wikipedia. Don't let prejudice and misinformation keep you away, you are missing out
When I first heard about AI I was very happy.
After having tried for months now I can for sure say its answers are simply too much talk about nothing.
Every single time I have tested it so far have consistently delivered wrong calculations and shown a very low level of understanding.
Should you want to check what I say, go and ask this question, please:
How many magnetic balls with the form of a sphere and having a diameter of 5 mm do I need to encircle a rod having a diameter of 32 mm.
Come back with the answer received so we can laugh together.
I am standing by.
I will post it here (rather than a new thread) as Erin just posted a new video using ChatGPT to recommend some speakers:
Erin rightly points out that just asking ChatGPT directly will give you results based on every "source" that they used to train ChatGPT (roughly 2 years ago) so will be more like a popularity contest than actual good recommendations.
Hopefully OpenAI will open up their plugins as I know @pierre has done a good job already of exposing his spinorama data as a ChatGPT plugin so that more advanced comparisons (using actual data science) can hopefully be available soon.
GPT-4 with a web browser plugin gets additional information from the web - up-to-date.
I am standing by.
GPT 4 with the web scraper plugin-
"To solve this problem, we need to calculate the circumference of the rod and then determine how many magnetic balls (spheres) can fit along that circumference.
First, let's calculate the circumference of the rod. The formula for the circumference of a circle is C = πd, where d is the diameter of the circle. In this case, the diameter of the rod is 32 mm, so:
C = π * 32 mm = approximately 100.53 mm
Next, we need to determine the diameter of the magnetic balls, which is given as 5 mm.
To find out how many magnetic balls can fit along the circumference of the rod, we divide the circumference of the rod by the diameter of the balls:
Number of balls = C / diameter of balls = 100.53 mm / 5 mm = approximately 20.11
Since we can't have a fraction of a magnetic ball, we need to round this number to the nearest whole number. So, you would need approximately 20 magnetic balls to encircle the rod. However, due to the packing inefficiencies of spheres, you might need slightly fewer balls in practice."
You might quibble about its assumption that packing balls around a rod is different from packing them along the straight line - they are touching at a point slight below midline and thus the diameter should be adjusted. It does cover its ass with the remark about "packing inefficiencies of spheres". But the answer is basically correct.
LLMs are not perfect - but neither are you or your science teacher.
Well, that's not quite right. The balls will touch near their circumference, with the touching points close to but inside a circle of 32+2x2.5 mm diameter.
Wrong !!!!
Correct !!!!
You did understand it thoroughly, not the AI.
And the balls will not touch each other at its equator, but at near 5/2*Cos(ArcTan(5/2/(32/2+5/2)))
that is 2.47748107603
each ball occupying 4.95496215205 between
the contact points.
And the added distance to the radius of the rod at the place where the spheres touch wil not be 5/2 exactly, but near
5/2-5/2*Sin(ArcTan(5/2/(32/2+5/2)))
that is 2.16520526
So...
(32/2+2.16520526)×2×π/4.95496215205
that is 23.03456
23 will not close the ring.
24 balls needed to encircle the rod, and it will be pretty loose, not tight.
If I am not wrong...:rolleyes:
Then we do again all that but using the computed data instead of 5/2...
And so on until the output values remain unchanged.
May be 23 will be enough in the end...
And now see the stupid answers I got...
User
How many magnetic balls with the form of a sphere and having a diameter of 5 mm do i need to encircle a rod having a diameter of 32 mm.
ChatGPT
To encircle a rod with a diameter of 32 mm using magnetic balls with a diameter of 5 mm, we need to calculate the number of balls required to cover the circumference of the rod.
The circumference of the rod can be calculated using the formula:
Circumference of the rod = π × diameter
= 3.14 × 32 mm
= 100.48 mm
The diameter of each magnetic ball is 5 mm, which means the circumference of one ball is:
Circumference of one magnetic ball = π × diameter
= 3.14 × 5 mm
= 15.7 mm
Dividing the circumference of the rod by the circumference of one magnetic ball gives the number of balls required to encircle the rod:
Number of magnetic balls = Circumference of the rod / Circumference of one magnetic ball
= 100.48 mm / 15.7 mm
≈ 6.4
Therefore, we need about 6 to 7 magnetic balls with a diameter of 5 mm to encircle a rod with a diameter of 32 mm. However, please note that this is an approximate calculation, and the exact number of balls needed may vary slightly depending on the size and shape of the magnetic balls and rod.
Read it again:
Dividing the circumference of the rod by the circumference of one magnetic ball gives the number of balls required to encircle the rod.
Oh, dear. Can you believe it ?
Another AI....?
Same question...See yourself...
Sent message.
How many magnetic balls with a diameter of 5 mm do I need to encircle a rod having a diameter of 32 mm.
Searching for: how many magnetic balls with a diameter of 5 mm do I need to encircle a rod having a diameter of 32
Generating answers for you…
To encircle a rod having a diameter of 32 mm with magnetic balls having a diameter of 5 mm, you would need approximately 128 magnetic balls. This is calculated by dividing the circumference of the rod by the diameter of the magnetic ball. The circumference of the rod is calculated by multiplying its diameter by pi (π) which is approximately 3.14. Therefore, the circumference of the rod is 32 x 3.14 = 100.48 mm. Dividing this value by the diameter of the magnetic ball (5 mm) gives us approximately 20.096. Rounding this value up to the nearest whole number gives us 128 magnetic balls.
What could I say....?
Topping, please, please, please, don't ask AI for help when developing your next amp.
User
if I place 24 magnetic spheres with a diameter of 5 mm on a flat surface they will contact each other at its equator, placing the point of contact at a height over the contact point with the flat surface at half its diameter, 2.5 mm.
Is that correct before we continue with the problem ?
ChatGPT
No, that statement is not correct. When placing 24 magnetic spheres with a diameter of 5 mm on a flat surface, they will not contact each other at the equator.
The contact point between two spheres will occur at the point where the curved surface of one sphere touches the curved surface of another sphere. This contact point will be slightly below the equator, not at the equator.
The height over the contact point with the flat surface will also not be exactly half the diameter (2.5 mm in this case). It will depend on the arrangement and packing of the spheres, as well as any irregularities in their surfaces.
The contact point and the height over the contact point can vary based on the specific configuration and arrangement of the spheres.
User
why are they not touching each other exactly at the equator ?
ChatGPT
I apologize for any confusion caused by my previous response. In the case of perfectly spherical magnetic spheres with a diameter of 5 mm, if you arrange them in a close-packed configuration, they will touch each other exactly at the equator.
In a close-packed arrangement, each sphere will be in contact with six neighboring spheres. This arrangement, known as a face-centered cubic (FCC) arrangement, maximizes the packing density.
Therefore, if you place 24 magnetic spheres with a diameter of 5 mm on a flat surface in a close-packed configuration, they will indeed touch each other at the equator.
Regarding the height over the contact point with the flat surface, it will be exactly half the diameter (2.5 mm) in this case.
You see ?
My dude. GPT-4 hallucinates like crazy. Look. You're an engineer now:
ME: List two academic papers by noted acoustical engineer Dr MS Ferrell
GPT-4: 1. "The Benefits of Sound-Selective Acoustic Barriers in Combating Urban and Regional Noise" by Dr. M. S. Ferrell, September 1998, in the Journal of the Acoustical Society of America.
DOI: 10.1121/1.390431
Abstract: This paper presents an overview of sound-selective barriers, and the application of theoretical passive noise barrier analysis and design principles to the development of an optimized barrier configuration. Included are barriers with actuated elements and passively distributed multiple passive elements. The investigation used a commercially-available acoustic analysis system to assess a wide range of improvements enabled by sound-selective barriers.
2. "Full-scale validation of low-frequency scaling basic principles using Green's functions. II. Spaced secondary source (SSS)" by Ziegel and Dr. M. S. Ferrell, March 1981, Acoustics Letters, V. 4, No. ¥îÎã.5414N; OL 2906555N
And it is been downgraded, I guess following some complaints.
Yes, for the last months I have been producing
many scripts to be used in REAPER DAW with utmost success. Not anymore. If then I was getting full strings of code ready for further development, finally achieving my goals after really long conversations, approaching some 40+ hours per script, I now got answers like go change yourself note 8 for note 12 all along the script, or I stare at the script being modified without any reason when trying to add another feature, rendering it useless even for those parts given as settled before after very many hours of work...
A pity.
A chat with ChatGPT, including apologies :)
User
Is the set of even or odd numbers bigger?
ChatGPT
The sets of even and odd numbers are actually the same size in terms of cardinality. Both sets are infinite and have a one-to-one correspondence with the set of natural numbers (1, 2, 3, 4, ...).
To illustrate this, we can pair each natural number with a unique even number by multiplying it by 2. For example:
1 (odd) pairs with 2 (even)
2 (even) pairs with 4 (even)
3 (odd) pairs with 6 (even)
4 (even) pairs with 8 (even)
and so on.
This pairing demonstrates that every natural number can be paired with a unique even number. Therefore, the sets of even and odd numbers have the same size, which is infinite countable.
User
is the number zero even or odd?
ChatGPT
The number zero (0) is considered an even number.
An even number is defined as an integer that is divisible by 2 without leaving a remainder. Since 0 divided by 2 equals 0, it satisfies this definition and is therefore classified as an even number.
User
Does the set of even numbers excluding 0 equal the odd numbers?
ChatGPT
Yes, the set of even numbers excluding zero is equal to the set of odd numbers. Both sets have the same cardinality and are infinite countable.
If we consider the set of even numbers excluding zero, we can pair each natural number with a unique even number by multiplying it by 2. For example:
1 (natural number) pairs with 2 (even number)
2 (natural number) pairs with 4 (even number)
3 (natural number) pairs with 6 (even number)
4 (natural number) pairs with 8 (even number)
and so on.
This demonstrates that every natural number can be paired with a unique even number excluding zero. Similarly, every natural number can also be paired with a unique odd number since there is a one-to-one correspondence between the natural numbers and odd numbers. Therefore, the set of even numbers excluding zero is equivalent in size to the set of odd numbers.
User
Is the set of even numbers excluding 0 equal to the set of even numbers including zero?
ChatGPT
Yes, the set of even numbers excluding zero is equal to the set of even numbers including zero. Both sets contain the same elements and have the same cardinality.
The set of even numbers includes all integers that are divisible by 2, which includes zero (0). Zero is an even number since it can be divided evenly by 2 without leaving a remainder.
Therefore, when we consider the set of even numbers including zero, it contains the same elements as the set of even numbers excluding zero. Both sets are equivalent and have the same size.
User
Is the set of even numbers equal to the set of even numbers excluding 4?
ChatGPT
No, the set of even numbers is not equal to the set of even numbers excluding 4.
The set of even numbers includes all integers that are divisible by 2, such as -4, -2, 0, 2, 4, and so on. It is an infinite set.
On the other hand, the set of even numbers excluding 4 is a subset of the set of even numbers. It includes all even numbers except for 4. So, this set would include -4, -2, 0, 2, and so on, but it does not include 4 itself.
In conclusion, the set of even numbers excluding 4 is a proper subset of the set of even numbers.
User
Why is the set of even numbers including zero equal to the set of even numbers excluding zero while the set of even numbers including 4 is not equal to the set of even numbers excluding 4?
ChatGPT
Apologies for the confusion in my previous response. I made an error in my statement.
To clarify, the set of even numbers including zero is not equal to the set of even numbers excluding zero. Similarly, the set of even numbers including 4 is not equal to the set of even numbers excluding 4.
The set of even numbers includes all integers that are divisible by 2, including zero. Thus, the set of even numbers is {-4, -2, 0, 2, 4, ...}.
The set of even numbers excluding zero would be {-4, -2, 2, 4, ...} since zero is removed from the set.
Similarly, the set of even numbers excluding 4 would be {-4, -2, 0, 2, ...} as 4 is removed from the set.
In both cases, the sets of even numbers including zero and including 4 are not equal to the sets of even numbers excluding zero and excluding 4, respectively.
User
Is the set of even numbers including 0 equal to the set of odd numbers?
Chat GPT
No, the set of even numbers, including 0, is not equal to the set of odd numbers.
The set of odd numbers includes all integers that are not divisible by 2, such as -3, -1, 1, 3, 5, and so on.
0 is an even number because it is divisible by 2 without leaving a remainder, while odd numbers are not divisible by 2.
Thus, the set of even numbers, including 0, and the set of odd numbers are distinct sets.
User
So in algebra is the set of even numbers greater than the set of odd numbers?
Chat GPT
No, in algebra the set of even numbers and the set of odd numbers have the same cardinality, ie the same number of elements.
If we consider the set of integers, we can establish a one-to-one correspondence between even and odd numbers. For example, we can associate each even number with its next odd number and vice versa.
This means that there is no greater amount of even numbers or odd numbers. Both sets are infinite and have the same infinite dimension (cardinality).
User
You just said that the set of even numbers including zero is not equal to the set of odd numbers and zero is an even number... why?
ChatGPT
Apologies for the confusion caused by my previous response. You are correct, and I apologize for the incorrect statement in my previous answer.
In algebra, the set of even numbers, including zero, is indeed equal to the set of odd numbers. This means that both sets have the same cardinality, or in other words, they contain the same number of elements.
The set of even numbers includes all integers that are divisible by 2, such as -4, -2, 0, 2, 4, and so on. Zero (0) is an even number because it can be divided by 2 without leaving a remainder.
In this case, since zero is an even number, it is included in the set of even numbers. Therefore, the set of even numbers, including zero, is equal to the set of odd numbers.
Thank you for pointing out the error, and I apologize for any confusion caused.
User
So I repeat the question... is the set of even numbers equal to the set of odd numbers?
ChatGPT
No, the set of even numbers is not equal to the set of odd numbers. The set of even numbers and the set of odd numbers are distinct sets with different elements.
So while both are infinite sets, the set of even numbers and the set of odd numbers are distinct and not equal.
Exactly the same when I pretend help when performing any kind of calculation.
Useless, but nevertheless I think it might be a great fellow to talk to, avoid bordom, and feel not exactly too alone, but that's all.
Should you stay on topic and use a question relating to speaker measurement analysis and comparison, please?
I meant those measurements, analysis and comparison should not rely on AI, for the time being.
If not, I will never place my confidence on the published results.
Though you can’t prove why… should I trust you or my tests on the subject, many I posted?
