TimW
I just got this very interesting custom made enclosure. The maker intended it to be a preamplifier using a Nelson Pass design but never got around to building that. What he did end up putting in it was a miniDSP along with the simple power supply that is still in the enclosure.
The front panel is a solid piece of wood that the maker must have machined and then stained. The back panel is a chunk of aluminum that he said he had machined by a friend, it is attached to the other pieces with a wooden frame. He must have had the back and top panels anodized this blue color after cutting them to size. I am very impressed by the craftsmanship.
There is this nice wooden connector plate that was made for a couple of USB connectors. He made it removable so that different connectors could be used. There is also 6 pairs of holes for audio connectors to mount, right now there are 3 pair of fancy Rhodium plated Cardas RCA jacks there.
The sides of the enclosure are made from Conrad heatsinks. Actually it was one MF35-151.5 model heatsink that has been cut in half to create 2 7/8" (73 mm) tall heatsinks. This should make thermal resistance just slightly worse than that of the MF35-75 model which is 0.32 C/Watt for 80° C rise.
The simple power supply he built in this enclosure must have powered the miniDSP unit through a regulator. It has a nice cast cover over the AnTek AS-1212 transformer, but no fuse protection! Needless to say I will probably not be using this power supply, at least not without the addition of a fuse.
At first I was considering using this enclosure just to hold a miniDSP 2x4 HD, making it prettier and more convenient to connect. Then I thought about also mounting power supplies in it for external amplifiers or other equipment, but that doesn't make a whole lot of sense. I would really like to make use of the nice heatsinks and build something suited for this enclosure.
So my current plan is to install some Neurochrome amplifiers in this thing. I could make use of a stereo power amplifier in my current systems so that's one option. But I'm more interested in making a 4 channel amp for an active two way system. I have DSP units lying around from previous DIY active speaker projects and I've been itching to build some LXmini's...
@tomchr I've been perusing your site and considering my options. I like the Modulus-86 specs but building 4 channels would be a bit pricey. For that reason I might go with the LM3886 Done Right if I go with 4 channels rather than 2. But what I really want to ask you is how much amplifier do you think I can stuff in this case? Do you think these heatsinks will handle 4 Modulus-86 or LM3886 amps? Will they even handle two? And if I do go with 4 amps, do you strongly recommend the Power-686 over the Power-86? Not sure how many parts will fit in the case but in any layout I plan to also install your Intelligent Soft Start board. Would you strongly recommend the Guardian-86 for use with your amplifiers?
I also have this AnTek AS-3222 transformer laying around that just barely fits in the case.
Is this suitable for multiple Neurochrome Modulus-86 or LM3886 amps?
