function9
Yes I have 2 in stereo I use regularly.I suppose it is mono.
If you buy two, can you assign "left and right"?
Works for me once setup.Yes, but apparently it's unreliable. Quick Google suggests that they had a solid implementation, but it was too close to Sonos', they threatened a lawsuit, and the new implementation is bad.
This may be what Google says, certainly not what these devices do. I have Google Mini speakers all over the house and I certainly notice online ads about the topics I was discussing with someone else in the house soon after the fact.f the microphone is enabled, all audio is processed by some kind of wake word detection engine. This engine only has one task: to check if you say "OK Google", and this is done locally, i.e. the audio is not recorded or shared with Google.
I have 4 of these and I run them in two stereo pairs mainly for Roon. Like waynel, I have the mic switched off all the time and they work normally. I pulled the grills off and disconnected the LED instead of using tape, but same result. The mic switch is a physical "clicky" switch on the back. It is not a button or other type of soft switch.I have two pairs of these and they work fine as stereo pairs. There is a switch on the back to turn off the mic but it leaves orange lights on the front. I took off the grill, covered the LEDs with black electrical tape and replaced the grills. Now no mic and no lights.
I've noticed that as well. For instance we talked about where we should go for a hike on the weekend and hours later I started seeing trail guide articles for my area in my news feed.This may be what Google says, certainly not what these devices do. I have Google Mini speakers all over the house and I certainly notice online ads about the topics I was discussing with someone else in the house soon after the fact.
Spooky. It will be troubling if information about Viagra or Preparation H start showing up incidentally for some unfortunate souls.I've noticed that as well. For instance we talked about where we should go for a hike on the weekend and hours later I started seeing trail guide articles for my area in my news feed.
Three options here I think.I've noticed that as well. For instance we talked about where we should go for a hike on the weekend and hours later I started seeing trail guide articles for my area in my news feed.
What is your indicator that the "audiophile hobby" is dying?
This review thread is probably not the place for discussion on this topic so I'll close my remarks with this.Three options here I think.
Either your brain is playing tricks on you, making you imagining things, or Google is listening in, or Google knows you already so well that it can predict your behavior.
All three would make me nervous, the last probably the most.
There is a chance that my daughter did a search on the topic and Google associated the WAN IP address for that search with everyone on my LAN.
Yeah for $160 less they can have my data, contacts and clog my inbox.Back to our overheated planet!
Where they can be had for 30, in any currency, no bit coin?
At their current price, they are $ 160 less per pair than new Adam Audio 3DV, here in Canada. At USD 30, they are almost four times cheaper than Adam D3V, data harvesting or not!
But do you still get ads for what might be talked about in the room with the devices?I have two pairs of these and they work fine as stereo pairs. There is a switch on the back to turn off the mic but it leaves orange lights on the front. I took off the grill, covered the LEDs with black electrical tape and replaced the grills. Now no mic and no lights.
You sell yourself short.Yeah for $160 less they can have my data, contacts and clog my inbox.![]()
That is a myth that they would like you to believe. There are ways (how else could there be a "dark web").Hope you aren't using some sort of computer with internet access to write this or else you are in for a surprise.
"They" being whom in this instance?That is a myth that they would like you to believe. There are ways (how else could there be a "dark web").
Now we just need to know what portion of a soul is made from data, and we can calculate what a soul might go for.Yeah for $160 less they can have my data, contacts and clog my inbox.![]()
