- Thread Starter
- #21
Thank you very much! I will follow the link.If you want a flat response in that budget actives are your best bet. In link i gave you read the reviews for the more capable ones because they all have trade offs (spl, hiss, connectivity etc). Then go, listen, compare.
As for the flat response I understand that this is an ideal situation which may be practically unachievable. Definitely, I would like the response as flat as possible and makes sense without a room treatment which I am reluctant to do.
My listening experience suggests that I do need frequencies up to 26kHz (even though they are considered inaudible). As for the lower bound I am not sure. At the same time, the laptops and smartphones which I have used so far have never played symphonies particularly well. I suspect that this may be because of the lacking bass. Coming back to flatness, I do not have a feel of how much of it I need. Perhaps, requiring an ideally flat response would be an overkill.
