solderdude
95dB at 130Hz and 70dB at 300Hz ... that's 25dB difference.I think this doesn't look too bad
Due to the way the hearing works (ERB) it isn't perceived that way though.
Look at both HD681 and HD650 and compare.
Such is the problem with measurements and perception.
If you want an open headphone that translates well to calibrated nearfield monitors you can simply buy the JT7.
It will get you there with no EQ. It will cost you € 120.-
You can't buy a cheap set of decent monitors with good bass extension and certainly not at 100dB SPL for that money.
You could EQ 600Hz a bit (-2dB wide bandwidth) if needed.
No need to think about this any further.
HD650 with EQ will get you there too IF you apply the correct EQ in the lows.
