Speedskater
'P48' in post #41 details the best connection method.So when making a RCA > XLR cable, is it better to connect pin 1 and 3 at the RCA side (ie, attach both to the RCA shield), or jump them on the XLR side?
RANE recommends:
RCA Out to XLR In:
2-conductor shielded cable
shield lifted at the RCA and connected to pin 1
common ground from the RCA connected to pin 3
XLR Out to RCA In:
shield lifted at the RCA and connected to pin 1, then shorted to pin 3
Source: https://www.ranecommercial.com/kb_article.php?article=2107
But it probably depends on the circuit of the input.
On wiring a DIY project. Note, I won't use the lower case 'ground' it's just to confusing.
1] AC power attach the Safety Ground to the chassis near where the cord enters the chassis.
2] XLR chassis connectors. Each pin 1 to the chassis very near that connector.
3] Audio circuit common. Only one attachment to the chassis.
4] DC supply common. Only one attachment to the chassis.
5] Both of these attachments should be at the same point and it should be near the input connectors.
RANE recommends:
RCA Out to XLR In:
XLR Out to RCA In:
So for the record, your cable was as follows:So I finally got around to doing a first test of my amp build with my self made cables. I had built cables for the RCA Out > XLR In path. On the RCA side, the cable shield lifted (not connected to anything), and on the XLR side cable shield connected to Pin 1.
I got this loud buzzing sound as soon as I connected the cables.
Yeah, shorting cable shield and ground on the RCA side fixed it. Did that last night and now it works perfectly.So for the record, your cable was as follows:
RCA ground --> hot --> XLR pin 3
RCA signal --> cold --> XLR pin 2
(open) --> shield --> XLR pin 1
Correct?
That should work as long as both sides are grounded somewhere (e.g. PC to active monitors, both IEC Class I devices with PE connection). If one end is floating, change to
RCA ground (2) --> shield --> XLR pin 1
instead, as suggested. This will provide a ground connection for the floating side.
"One side floating" generally means that there is some capacitive coupling to mains through either the mains transformer (several hundred pF) or filter capacitors (nF). This may mean that your balanced input with its high input impedances ends up being subjected to tens of volts of common-mode AC superimposed on the signal, driving it into clipping or at least giving its CMRR a lot to do (and a basic balanced input won't have more than 40-60 dB of CMRR on tap). Once the mains leakage currents are given a low-impedance path to ground, the voltage between floating side ground and the grounded side (and hence common-mode voltage) will be substantially reduced - possibly by as much as 80 dB.
If both sides are grounded, the cable with shield connection also works but may be somewhat prone to ground loop issues if either the balanced side suffers from a Pin 1 Problem or the connection from RCA ground to star ground on the unbalanced sided isn't quite as low impedance as it could be. It should still be better than unbalanced though.
This should have read:So for the record, your cable was as follows:
Correct?
I know this thread is kind of old, but would you say that the way you wired your cable to eliminate the hum followed this diagram I see on the Ghent website for their cables?Yeah, shorting cable shield and ground on the RCA side fixed it. Did that last night and now it works perfectly.
It connects my Yamaha AVR (unbalanced) to my power amp.
Thanks
I agree, China is far... but the value for money of Ghent audio products is excellent. BTW they also sell nice enclosures for class D amplifiers.
I know it's an old post. Any advantages of using a mic cable (2 signal + shield) over rg174 and splitting the shield on the xlr?Minor correction:
RCA ground --> cold --> XLR pin 3
RCA signal --> hot --> XLR pin 2
Correct?
How silly. No biggie, switching the leads of a twisted pair around at both ends would have made zero difference electrically, it's just a matter of convention.
That's what I've found as well, care to elaborate on the reasoning behind that?for a RCA output to an XLR input a Shielded Twisted Pair (STP) is always better than a coax cable.
'mic cable' is a sub-set of Shielded Twisted Pair (STP)
it is optimized for robust construction, flexibility and low handling noise.
for an interconnect it has no advantages over other STP cables.
